Thread: Best way to change O2 sensor/ECT sensor?
Results 1 to 14 of 14
  1. #1 Re: Best way to change O2 sensor/ECT sensor?
    I live here. TLSheff's Avatar
    Quote Originally Posted by stlunatics2oo3 View Post
    if your set on taking it off and just replacing you could buy the o2 socket which is a 7/8's and use an extension, or cut the pig tail and use a 7/8 socket but then I dont know if you would have enough room to get the new one in using the wrench method
    You need one of these, like 10-15 bux at your local auto parts store, buy one, youll need it later at some point or another
  2. #2 Re: Best way to change O2 sensor/ECT sensor?
    GT Level Member starscream5000's Avatar
    Kentucky
    That socket would not fit on my o2, the sensor was too fat to fit inside of the sleeve. I had to use an open end socket for mine.
    2005 GTP - AL 605's gapped at .055", SD headers, WAI with 9" cone air filter, 180 degree t-stat, green coolant, otherwise stock.
  1. TPS Sensor
    By Derrick4625 in forum Introductions/Noob Questions
    Last Post: 09-09-2010, 07:32 AM
  2. camshaft sensor or crank sensor?
    By Viper in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-06-2010, 04:43 PM
  3. Picture request of Coolant Temp Sensor and TPS sensor parts
    By David A Smith in forum Shops and Community Heroes
    Last Post: 06-11-2010, 11:05 AM
  4. maf sensor
    By betsgtp in forum General Tech Discussion
    Last Post: 04-21-2009, 02:15 AM
