Thread: Best way to change O2 sensor/ECT sensor?
Results 1 to 14 of 14
  1. #1 Best way to change O2 sensor/ECT sensor?
    dfw, tx
    For the O2: Go in from the top or from underneath? If I unbolt the dogbones could the motor come foward enough to get back there with a wrench?
    And for the ECT: Do I need to take the exhaust crossover off to get to it? Looks like it's the only way to get there with a socket.
  2. #2 Re: Best way to change O2 sensor/ECT sensor?
    Charles City, IA
    02 get an 02 socket and go from the top
    ect take off the left dog bone bracket then use a 19mm socket.
    SMGPFC Two Nipple General
  3. #3 Re: Best way to change O2 sensor/ECT sensor?
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    spray the 02 sensor with penetrating lubricant about 2 hours before, they can be a sob to get off
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  4. #4 Re: Best way to change O2 sensor/ECT sensor?
    dfw, tx
    No need to move the motor forward? I can get a wrench on it now but there's no room to turn it.
  5. #5 Re: Best way to change O2 sensor/ECT sensor?
  6. #6 Re: Best way to change O2 sensor/ECT sensor?
    dfw, tx
    try harder.
    hey thanks for your input!!!
  7. #7 Re: Best way to change O2 sensor/ECT sensor?
    SE Level Member stlunatics2oo3's Avatar
    Michigan
    if your set on taking it off and just replacing you could buy the o2 socket which is a 7/8's and use an extension, or cut the pig tail and use a 7/8 socket but then I dont know if you would have enough room to get the new one in using the wrench method
  8. #8 Re: Best way to change O2 sensor/ECT sensor?
    I live here. TLSheff's Avatar
    Quote Originally Posted by stlunatics2oo3 View Post
    You need one of these, like 10-15 bux at your local auto parts store, buy one, youll need it later at some point or another
  9. #9 Re: Best way to change O2 sensor/ECT sensor?
    Michigan
    yeah that is the 02 sensor socket I was referring to. its really your call OP on which way you would like to get it off.
  10. #10 Re: Best way to change O2 sensor/ECT sensor?
    you can pull the motor forwards a little more, but the o2 sensor placement just sucks in general. you kinda just have to get in there and have at it.
  11. #11 Re: Best way to change O2 sensor/ECT sensor?
    GT Level Member starscream5000's Avatar
    Kentucky
    That socket would not fit on my o2, the sensor was too fat to fit inside of the sleeve. I had to use an open end socket for mine.
    2005 GTP - AL 605's gapped at .055", SD headers, WAI with 9" cone air filter, 180 degree t-stat, green coolant, otherwise stock.
  12. #12 Re: Best way to change O2 sensor/ECT sensor?
    Charles City, IA
    You bought the wrong one then.
  13. #13 Re: Best way to change O2 sensor/ECT sensor?
    Kentucky
    They were both the same size, but the inside of the socket was a little too narrow. Doesn't really matter though as the other socket worked just fine.
  14. #14 Re: Best way to change O2 sensor/ECT sensor?
    Quote Originally Posted by starscream5000 View Post
    Truth^ One of our techs has 2 different ones, both the "same" size, but one wouldnt work to remove my 02 sensor when we did the motor swap... dunno why but it happens
  1. TPS Sensor
    By Derrick4625 in forum Introductions/Noob Questions
    Last Post: 09-09-2010, 07:32 AM
  2. camshaft sensor or crank sensor?
    By Viper in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-06-2010, 04:43 PM
  3. Picture request of Coolant Temp Sensor and TPS sensor parts
    By David A Smith in forum Shops and Community Heroes
    Last Post: 06-11-2010, 11:05 AM
  4. maf sensor
    By betsgtp in forum General Tech Discussion
    Last Post: 04-21-2009, 02:15 AM
