Thread: 99 GTP Strange problems
Results 1 to 4 of 4
msilverwood 99 GTP Strange problems 11-14-2010, 12:41 PM
Fivefingerdeathpunch Re: 99 GTP Strange problems 11-14-2010, 04:39 PM
SuperSport Re: 99 GTP Strange problems 11-14-2010, 05:59 PM
msilverwood Re: 99 GTP Strange problems 11-14-2010, 07:18 PM
  1. #1 99 GTP Strange problems
    Nov 2010
    New Hampshire
    I have a 1999 Pontiac Grand Prix GTP - got about 186,000 miles on it. Never seen a garage (as in, always stored outdoors) Unfortunately it's a rust bucket, but no other choice. Here's a list of issues:
    HUD dims and goes out and comes back on at random
    Tachometer - will be reading normally and then will just go to zero, and when it does, the TCS Off Light comes on. It will often go back the other way and be working again on the same drive.
    Clock - the numbers will often get wigged out or go blank. Radio, CD et al works fine throughout.
    Heat and A/C Fan - not working at all - either in Auto or in manual. There is still heat and cooling going on, as I can feel it coming out of the vents but no force behind it. And this is no good since I live in the northeast, and soon the blower and heater will need to be 100% for safety if nothing else.
    And the last weird problem is the rear speakers go dead at random. It's to the point where I'm surprised they are on at all.
    What is the common denominator to all of this?? I've read it could be the Blower Resistor, the Resistor Pack, the blower motor resistor, or the Ignition switch. I'm not totally qualified to repair any of this but if need be I can. Can't afford to take it in to the dealer for what's sure to be thousands of dollars.
    Any ideas?
  2. #2 Re: 99 GTP Strange problems
    the tach problem is your Crank postion sensor. Its a pretty common problem
  3. #3 Re: 99 GTP Strange problems
    GTP Level Member SuperSport's Avatar
    Michigan
    The rear speakers just die. Its a common problem. Dont bother chasing wires or connections, just replace both 6x9s and youll be back in business.
    2001 Grand Prix GT Coupe
    Comp G Wheels - SS Corners - Infinity Sound - Tint - Digital DIC Swap - 893 Fogs
  4. #4 Re: 99 GTP Strange problems
    Nov 2010
    New Hampshire
    Great - Thanks for the info. I appreciate it.
  1. strange problem
    By LSXHP in forum General Tech Discussion
    Last Post: 01-15-2011, 01:35 AM
  2. strange shaking
    By occrocks in forum General Tech Discussion
    Last Post: 12-18-2010, 01:19 PM
  3. For some strange reason
    By TorqueAutoMotiv in forum Off Topic Discussion
    Last Post: 06-12-2010, 07:53 PM
  4. very strange problem.
    By maniakmyke in forum General Tech Discussion
    Last Post: 03-04-2010, 04:45 AM
  5. strange issue?
    By GTPJOE90 in forum General Tech Discussion
    Last Post: 06-29-2008, 12:27 AM
