Thread: 02 gt problem
Results 1 to 12 of 12
  1. #1 02 gt problem
    SE Level Member 02PrixGT's Avatar
    Canada
    going hwy speed car started 2 smoke smelled like burnt dexcool its not a hose its lower and closer to the engine wtf is it? i was thinking trans cooler line but i dont know? ps thanks for help in advance much appreciated
  2. #2 Re: 02 gt problem
    Jul 2008
    sumter,south carolina
    upper intake manifold is probably shot.. common issue on GT's
    02 GTP with mods 05 GP for DD
  3. #3 Re: 02 gt problem
    Canada
    how much that go for
  4. #4 Re: 02 gt problem
    Jul 2008
    i forget... theyre cheap though... try RockAuto Auto Parts
  5. #5 Re: 02 gt problem
    SLP, GTP or call it MUT! thunder71173's Avatar
    West Frankfort Illinois
    check with your local gm dealer there should be a recall on it if not a local mechanic should be able to do it for a 3 - 500
  6. #6 Re: 02 gt problem
    Jul 2008
    Quote Originally Posted by thunder71173 View Post
    to my knowledge there was never a recall on upper intake mani.. maybe ur thinking of front valve cover?
  7. #7 Re: 02 gt problem
    Canada
    another issue reverse is taking its sweet time to kick in after i shift does this effect low gear also cause there on the same band are they not?
  8. #8 Re: 02 gt problem
    my car had the supposidly had the recall on the upper intake performed before I bought it, thats why I said to check its worth making a phone call to find out. Also I wouldnt drive it like that because if thats what it is you have dexcool going into your motor oil and if you have enough in there it will cause severe wear to your lower crank bearing's and other crucial engine components!
  9. #9 Re: 02 gt problem
    Jul 2010
    Chicago
    i think 99's and under had plastic gasket thats why they made the recall cause the dex cool would destroy it. 2000+ should have the metal or whatever it is but they still r common to go out. get it pressure tested.
  10. #10 Re: 02 gt problem
    GTP Level Member SuperSport's Avatar
    Michigan
    I would check the plastic coolant elbows near the alternator before accusing the UIM.
    2001 Grand Prix GT Coupe
    Comp G Wheels - SS Corners - Infinity Sound - Tint - Digital DIC Swap - 893 Fogs
  11. #11 Re: 02 gt problem
    Pensacola, FL
    I believe Supersport is referring to the heater bypass. That was the first thing to kick when I got my 97 GT! I thought the gasket was leaking lol!!!
  12. #12 Re: 02 gt problem
    SE Level Member johnniep's Avatar
    nova scotia
    intake manifold would make the temp gauge run hot...plastic gaskets were junk and there was no recall but a group launched a class action against GM and they agreed to pay some money if you got the dealer to replace it but dealer costs are high. I always thought the 3.8 was bullet proof ...had them since 1987. I read about the problem in the Auto Trader ...called the GM guy who works on my cars, had all the top end gaskets replaced...at 115000kms the intake was starting to break down...waiting for him to do mt ss monte ..about 500.00
  1. HID problem
    By supercharged06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-27-2010, 07:37 PM
  2. big problem!
    By guitarguyucf in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-15-2009, 07:56 PM
  3. New problem
    By ryangtp89 in forum General Tech Discussion
    Last Post: 02-09-2009, 07:58 PM
  4. Replies: 6
    Last Post: 02-07-2009, 01:16 AM
  5. AC problem
    By evilpacker in forum General Tech Discussion
    Last Post: 07-22-2008, 04:34 PM
