Thread: HID problem
Results 1 to 6 of 6
  1. #1 HID problem
    GT Level Member supercharged06's Avatar
    capecod
    I just installed my HID's 8000k and i got the canceler kit and the slim ballasts.The relay harness ticks fast (getting constant power) wen the running lights are on but NOT when the headlights are on any suggestions
  2. #2 Re: HID problem
    West Side Michigan
    Did you make sure you disabled your daytime driving lights? By running lights do you mean the lights during the day? It's bad to run HID's with this setting because of the lower poer the daytime running lights give out.
  3. #3 Re: HID problem
    Willoughby, Ohio
    if you want to keep you automatic headlights then just unplug the wires that plug into the heat sink behind the panel on the side of the dash on the drivers side, problem solved
  4. #4 Re: HID problem
    capecod
    so by unplugging that plug on the heat sink ill have auto headlights but NO DRL?
  5. #5 Re: HID problem
    Willoughby, Ohio
    correct
  6. #6 Re: HID problem
    capecod
    Ok sweet thankyou guys
  1. ABS problem
    By fierogt in forum Brakes/Suspension/Chassis
    Last Post: 10-15-2009, 04:40 PM
  2. Anyone else have this problem?
    By PMave in forum Audio, Security & Visual Electronics
    Last Post: 10-04-2009, 08:09 PM
  3. HUD problem
    By the1euge in forum General Tech Discussion
    Last Post: 08-31-2009, 12:23 PM
  4. hid problem?
    By grand2000prixgtp in forum Visual/Body Modifications
    Last Post: 05-12-2009, 02:34 PM
  5. Gas Problem
    By flynn in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-07-2009, 10:27 PM
