Thread: Help me! More Tuning noob questions!
Results 1 to 4 of 4
Boosted02GTP Help me! More Tuning noob... 11-06-2010, 11:25 PM
Boosted02GTP Re: Help me! More Tuning noob... 11-07-2010, 12:05 PM
sic6 Re: Help me! More Tuning noob... 11-07-2010, 12:26 PM
TheOtherNick Re: Help me! More Tuning noob... 11-07-2010, 01:23 PM
  1. #1 Help me! More Tuning noob questions!
    SE Level Member Boosted02GTP's Avatar
    Feb 2009
    Long Grove IL.
    I looking into all my options. I want to go wide band... I need to make sure I don't blow my car up or run it lean. My mods are in my sig and I also need some advice on tuning software ect. I've been doing loads of research and I'm confident with the right tools I can install it, and tune the car if it even needs it. Advice?
    Should I buy the wide band stuff and go from there? Also I have a boost gauge and with the A/f gauge I was thinking of switching to a 3 gauge pillar set-up. What are you running for those of you that have a pillar pod?
    I need some legit advise because it's getting colder faster and I don't want to over boost the car and run it lean.
    I also found 2 problems after I ran those time in my sig..The front O2 sensor was about 1/2 unscrewed and my plugs were gaped at .45, now I have them at .55.. Would this of caused me to run slower?
    School me please
    2002 GTP coup 14.6 @ 94mph stock baseline 5-7psi.
    Headers w/o cat, plugs, fwi, 180* t-stat, 3.4, mail-in tune. 13.9 @ 99.75mph 2.2 60'..seeing only 7psi and a fresh set of weatherman snow tires
  2. #2 Re: Help me! More Tuning noob questions!
    Feb 2009
    Long Grove IL.
  3. #3 Re: Help me! More Tuning noob questions!
    GT Level Member sic6's Avatar
    san marcos, tx
    You do know the megasquirt system is a standalone ECM right. Not only would you have to assemble it you would also have to get a custom engine harness, not to mention alot of other stuff in order to make it work. I would just use hp tuners or Dhp tuner and do a wideband tune with it.
  4. #4 Re: Help me! More Tuning noob questions!
    Charles City, IA
    I would go with hptuners. Very user friendly.
    SMGPFC Two Nipple General
  1. audio noob with some questions.
    By Kizorm in forum Audio, Security & Visual Electronics
    Last Post: 07-24-2010, 04:11 PM
  2. pcm tuning questions with hp tuner
    By e6600 in forum General Tech Discussion
    Last Post: 03-29-2010, 07:36 PM
  3. Replies: 5
    Last Post: 05-11-2008, 07:10 PM
  4. Newbie questions on tuning
    By DesQ27 in forum Off Topic Discussion
    Last Post: 05-07-2008, 08:42 AM
  5. Tuning Questions
    By GPSEWidow in forum 3.1L V6 (LHO/LG8)
    Last Post: 04-11-2008, 01:06 AM
