Thread: Trunk wont pop and 6x9's Blown?
Results 1 to 4 of 4
Waterford69 Trunk wont pop and 6x9's... 11-06-2010, 11:13 AM
Colossus Re: Trunk wont pop and 6x9's... 11-06-2010, 01:28 PM
ZR1Vette09 Re: Trunk wont pop and 6x9's... 11-06-2010, 01:42 PM
SuperSport Re: Trunk wont pop and 6x9's... 11-06-2010, 04:59 PM
  1. #1 Trunk wont pop and 6x9's Blown?
    Nov 2010
    Waterford, MI
    Alright, Just bought a 1999 Grand Prix GT. The 6"x9"'s in the rear are not putting out anything at all. And the truck wont open with the Glove Box button, Key Fobs, or with just the key. I'm trying to figure out if they're related or what? I was thinking fuse till the truck wouldn't open even with the key. So any advice on both? Any known wiring problems in the trunk?
  2. #2 Re: Trunk wont pop and 6x9's Blown?
    Windsor (ON) Canada
    Maybe!!..MAYBE a crossed wire might have blown out both, dont think so though, speakers were probably just blown out by the previous owner.. do a quick search on how to replace/remove the rear speakers (little bit of work) requires removing the back bench, which isnt that hard (done it 10X times) and while your at it, you can easily crawl into the trunk and have a look around to what might be the problem. May even be able to pop it open from there.
  3. #3 Re: Trunk wont pop and 6x9's Blown?
    MO
    Idk if you guys have the emergency release for trunk, but make sure that opens up to rule out most mechanical issues. I'd get a voltmeter and start playing around.
    <brandonl2000> LMAO D!!
  4. #4 Re: Trunk wont pop and 6x9's Blown?
    GTP Level Member SuperSport's Avatar
    Michigan
    Rear speakers on 97-03 GP's tend to die. Its a common problem. Dont waste your time chasing wires unless some punk kid put in an "awesome" walmart setup. But if its stock, yep, blown speakers.
    2001 Grand Prix GT Coupe
    Comp G Wheels - SS Corners - Infinity Sound - Tint - Digital DIC Swap - 893 Fogs
  1. Blown 04 gtp
    By 91z in forum General Tech Discussion
    Last Post: 08-08-2010, 09:52 AM
  2. trunk wont pop
    By 99gpse in forum Audio, Security & Visual Electronics
    Last Post: 06-15-2009, 05:19 PM
  3. ughhh, trunk wont open!
    By black98gt in forum General Tech Discussion
    Last Post: 03-12-2009, 08:23 PM
  4. I think i'm going to get blown...
    By Tig in forum Off Topic Discussion
    Last Post: 03-29-2008, 09:03 PM
