Thread: Blown 04 gtp
Results 1 to 8 of 8
91z Blown 04 gtp 08-06-2010, 08:57 AM
Bio248 Re: Blown 04 gtp 08-06-2010, 09:08 AM
BillBoost37 Re: Blown 04 gtp 08-06-2010, 12:07 PM
91z Re: Blown 04 gtp 08-07-2010, 09:05 AM
gtpinsc Re: Blown 04 gtp 08-07-2010, 09:19 AM
Vegas_Matt Re: Blown 04 gtp 08-07-2010, 06:58 PM
Bio248 Re: Blown 04 gtp 08-07-2010, 07:00 PM
91z Re: Blown 04 gtp 08-08-2010, 09:52 AM
  1. #1 Blown 04 gtp
    Mn
    I have only had this car for two months and it kept on getting worse. I put one step colder plugs, a 180 thermo, new o2 and fuel filter and wires and it kept getting worse. I had it on the scanner yester day and ran it up to 5grand and number two let go. Now I find out that the motor is for 04 only? Does anyone know why and is it possible to use an older gtp motor? Need any help I can get! Thanks guys.
  2. #2 Re: Blown 04 gtp
    you can use any motor you want to, but youll need to make sure you use the 04+ top end because you have a DBW throttle body and returnless fuel lines. all the motors will physically bolt up to all the others parts, but you have to be aware of which one youre putting in due to the differences between the years and compression ratio.
  3. #3 Re: Blown 04 gtp
    04-08 is the easiest swappable motors.
  4. #4 Re: Blown 04 gtp
    Mn
    thanks for the info! I couldnt under stand why the bottom end wouldnt work from any other year. I guess when you look it up on an interchange thats why it looks like its for 04 only. Does anyone know what the differences are in compression through the years? they have an 03 there that the top end burned in a fire that I was going to look at. Thanks again
  5. #5 Re: Blown 04 gtp
    Jul 2008
    sumter,south carolina
    is ur cat clogged?
    02 GTP with mods 05 GP for DD
  6. #6 Re: Blown 04 gtp
    Donating Users Vegas_Matt's Avatar
    Jul 2010
    Las Vegas, NV
    if you do the swap like bio mentioned i want your top half of this one. i have L32 heads but an L67 intake mani.
  7. #7 Re: Blown 04 gtp
  8. #8 Re: Blown 04 gtp
    Mn
    Not sure if the cat is clogged but i will find out when i pull it and fix it with a sim if it is. Ill look into whats going on with the top half of the 03 if I go that route and let you know. Mainly just looking for compression info right now though.
  1. Blown 3.8
    By Viperkill97 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-31-2010, 03:59 PM
  2. Blown Motor
    By Sssnake08 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-03-2009, 04:33 PM
  3. blown 350z
    By 99prixgt in forum Off Topic Discussion
    Last Post: 08-21-2009, 11:56 PM
  4. Engine Blown
    By WagZ in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-16-2009, 12:53 AM
  5. I think i'm going to get blown...
    By Tig in forum Off Topic Discussion
    Last Post: 03-29-2008, 09:03 PM
