Thread: Side bolt mains
Results 1 to 11 of 11
  1. #1 Side bolt mains
    Mn
    does anyone know when they started using these. Are they only on the gtp blocks or are they on the standard as well. trying to find one to replace mine and am finding it tough to do. my car is an 04 gtp. thanks for any info.
  2. #2 Re: Side bolt mains
    Charles City, IA
    Your talking main caps? They do not have side bolts any of them.
    SMGPFC Two Nipple General
  3. #3 Re: Side bolt mains
    Mn
    My 04 has them. It has the normal bolts through the bottom of the mains into the block and smaller bolts that go through the side of the block into the mains. Kinda like the older ford motors.
  4. #4 Re: Side bolt mains
    St. Louis
    I think I recall seeing these on my 00 GT's block as well. Also the 01 Monte engine that replaced it. Both were Series-II motors.
    IIRC, its the first 3 mains that get the side bolts. They are usually overlooked due to being covered in oil/dirt.
    Jay
  5. #5 Re: Side bolt mains
    Charles City, IA
    Hmm must have over looked them.
  6. #6 Re: Side bolt mains
    Donating Users kfish's Avatar
    Ohio
    you did.
  7. #7 Re: Side bolt mains
    Mn
    Finally found info. all series 2 from 95 on up had these. They only difference with my block is that it has two knock sensor locations on each side of the block. That started from 04 on up. At least now I know what block to look for. Thanks for all the help guys!
  8. #8 Re: Side bolt mains
    They were on all the Series II blocks...and I think some of the later Series I engines. It was a big thing for the SBC to have Side bolt mains.
  9. #9 Re: Side bolt mains
    Ohio
    Quote Originally Posted by 91z View Post
    no, any series 2 also has 2 knock sensors. that was not new for 04+
  10. #10 Re: Side bolt mains
    series III blocks still are the exact same as series II blocks..... the casting on the side will say series II.
  11. #11 Re: Side bolt mains
    Quote Originally Posted by kfish View Post
    That was a new thing for '96.
    But anywho...QFT.
  1. bolt broke off mount brackets to block,where can i find new bolt
    By crystalterry89 in forum General Tech Discussion
    Last Post: 10-21-2010, 06:28 PM
  2. Driver side wiper arm slips down to the side mirror
    By kappian in forum General Tech Discussion
    Last Post: 04-05-2010, 08:43 PM
  3. rear end swevers side to side
    By 05grandprixgt in forum Brakes/Suspension/Chassis
    Last Post: 02-07-2010, 01:44 PM
  4. front drivers side sits higher than passengers side
    By tjvdubsport in forum Brakes/Suspension/Chassis
    Last Post: 06-12-2009, 06:21 PM
  5. Side mirror on driver's side
    By jokyfo in forum Shops and Community Heroes
    Last Post: 04-29-2009, 03:50 PM
