Thread: Car Problems...Need Advice!!!
Results 1 to 13 of 13
  1. #1 Car Problems...Need Advice!!!
    GTX Level Member nikkigpgt00's Avatar
    MI
    First, When I popped off my engine cover today and oil cap came flying off with it...Grrrr!!! Question is....can I drive the car a short distance to the auto store to get a new one??? I can't find the darn thing anywhere!!!
    Second, my engine light is on and stays on. I have noticed that it seems to run high Rpm's and when the car is started and just sitting it sputters a bit. Also, my gas gauge as not been working properly and majorly fluctuates, dunno if this could be related??? I have ran out of gas twice in the past few months. Any ideas???
    Third, my security light comes on periodically. Sometimes it goes off after a few minutes and other times stays on longer. What could this be?
    I'm just trying to get some ideas of what could be going on. Figures my extended warranty just ran out too!
  2. #2 Re: Car Problems...Need Advice!!!
    Jul 2008
    sumter,south carolina
    Do not.... I repeat do not drive it with oil cap off!!!!
    02 GTP with mods 05 GP for DD
  3. #3 Re: Car Problems...Need Advice!!!
    MI
    Great! I have no other car to get to the store with. Anything I can use to cover it temporarily?
  4. #4 Re: Car Problems...Need Advice!!!
    Jul 2008
    id look for the one u lost... if u drive it with anything that doesnt seal/cover that fill hole... ur gonna have oil everywhere under ur hood.
  5. #5 Re: Car Problems...Need Advice!!!
    MI
    It fell down into the hood somewhere but I could not see it!
  6. #6 Re: Car Problems...Need Advice!!!
    for a short ride u can use plastic wrap and a rubber band, its not a permanent fix tho, it will probably melt over time.
  7. #7 Re: Car Problems...Need Advice!!!
    Jul 2008
    u look under the car? its gotta be there somewhere... i wouldnt trust the plastic wrap.
  8. #8 Re: Car Problems...Need Advice!!!
    Jersey
    at least use duck-tape, if anything. Did you check the engine cradle? or behind the grill?
    16' wrx sti- stock
  9. #9 Re: Car Problems...Need Advice!!!
    MI
    Well I ended up getting a new one today...then later this evening the old one fell out and I have it now too. Its funny, the replacement was just a cap. What I lost was the whole tube with the cao attached, so I put the original back on.
    Even better! My battery died last night because I had Halloween music playing while I was handing out candy. This morning after I replaced the cap I jumped the car and then took it for a drive. My engine light has not come on since!!!!
  10. #10 Re: Car Problems...Need Advice!!!
    Jul 2008
    light will come back on.. battery dying reset ur PCM and killed the code.
  11. #11 Re: Car Problems...Need Advice!!!
    GTX Level Member EJOUIE's Avatar
    Newnan, GA
    ^if its electrical maybe it won't come back.
    97 GT white 4 door-SOLD
    Cherry 2005 Impala LS- Front and Rear GMPP Strut Tower Braces
  12. #12 Re: Car Problems...Need Advice!!!
    take that stupid neck off the valve cover and put just the cap on it. looks way better.
  13. #13 Re: Car Problems...Need Advice!!!
    SE Level Member Whiplash Performance's Avatar
    Hillsborough, NJ
    The SES light came on from the oil cap being off because it allows a large amount of air to enter the intake (through the pcv system), and will probably through a lean code of some sort.
    The fluctuation in the gas gauge is caused by the fuel level sensor in the gas tank. Usually because the tension on the wiper of the gas gauge sensor becoming weak or excessive play in the float arm.
    Whiplash Intense Performance Hillsborough, NJ
    Performance Parts & accessories| Powder Coating | Engineering
    Intensewhiplash.com
  1. need advice
    By buster in forum General Tech Discussion
    Last Post: 10-16-2010, 12:31 PM
  2. CAI advice
    By tayl5645 in forum General Tech Discussion
    Last Post: 07-16-2010, 10:08 AM
  3. **please help, need advice**
    By tmackster in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-05-2010, 11:40 AM
  4. Need advice on a GP
    By Brammer in forum Off Topic Discussion
    Last Post: 02-05-2009, 04:33 PM
  5. Advice.. New Car...
    By Vespers47 in forum Off Topic Discussion
    Last Post: 02-02-2009, 05:33 PM
