Thread: Car will stall when I turn it on while it's hot
Results 1 to 3 of 3
Vlad0691 Car will stall when I turn it... 10-16-2010, 11:11 PM
TheOtherNick Re: Car will stall when I... 10-17-2010, 10:18 AM
Vlad0691 Re: Car will stall when I... 10-17-2010, 11:53 AM
  1. #1 Car will stall when I turn it on while it's hot
    SE Level Member Vlad0691's Avatar
    Dacula, GA
    I have an '04 GT and when it's cold it starts right up strong, but if, let's say, I just drove it somewhere, turned it off for like 10 minutes and then try to turn it back on, it'll crank up and then stall unless I pump the gas a couple times. I think it might be my fuel pump going out? But I'm not sure, it'd be great if someone could give me a little bit more insight.
    I've only had the car for less than a year and it has about 125k miles on it, and I'm just now getting into working on it. Thanks in advance!
  2. #2 Re: Car will stall when I turn it on while it's hot
    Charles City, IA
    pumping the gas does nothing. Holding it to the floor tho puts it in clear flood mode and leans it out for start up. Run some injector cleaner threw it and see what happens.
    SMGPFC Two Nipple General
  3. #3 Re: Car will stall when I turn it on while it's hot
    Dacula, GA
    I have put injector cleaner through, but it did nothing. And I'm pretty sure.pumping the gas does something,, cause it wont start otherwise.
    Maybe I need to clean my throttle body and manifold?
  1. Dont like to turn left but easy to turn right
    By Randall in forum General Tech Discussion
    Last Post: 02-01-2013, 12:11 PM
  2. NEED HELP Car acting like it wants to STALL???
    By PTGsDaytona500GTP in forum General Tech Discussion
    Last Post: 09-03-2010, 09:16 PM
  3. stall
    By roadwarrior1 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-26-2009, 11:09 PM
  4. Start and Stall
    By l3enner in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-31-2009, 06:35 AM
  5. GP Wants To Stall
    By BADAZGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-25-2008, 07:41 AM
