Thread: HELP!**Fuel line replacement?**
Results 1 to 8 of 8
  1. #1 HELP!**Fuel line replacement?**
    Minnesota
    I need to replace the fuel line that goes from the engine to the fuel filter. Anyone have any tips suggestions? Looks pretty straight forward but only question is how to disconnect it on the engine side. It looks like just a rubber tube slips over the metal line but not sure?
    EDIT---Looks like the line is one piece that goes right up to the fuel rail. Does that sound correct?
  2. #2 Re: HELP!**Fuel line replacement?**
    Charles City, IA
    Yup one piece, you need a fuel line disconnect tool to take it off.
    SMGPFC Two Nipple General
  3. #3 Re: HELP!**Fuel line replacement?**
    SE Level Member Whiplash Performance's Avatar
    Hillsborough, NJ
    Yeah it sounds correct. You disconnect it at the fuel rail with a fuel rail disconnect tool.
    Sears and most auto part stores have these:
    Whiplash Intense Performance Hillsborough, NJ
    Performance Parts & accessories| Powder Coating | Engineering
    Intensewhiplash.com
  4. #4 Re: HELP!**Fuel line replacement?**
    Minnesota
    I will have to go pick up the tool. This fuel filter change is costing me! $108 for the line and whatever for the tool. And that is without the cost of the filter UGH!
  5. #5 Re: HELP!**Fuel line replacement?**
    Minnesota
  6. #6 Re: HELP!**Fuel line replacement?**
    Brewcity, WI
    ^yes
    also, just wondering...
    how many miles/year on the monte? is it a daily driver?
    you buying the fuel line from a dealer?
    this is what I ran into when I went to change mine...
    Self-denied SMGPFC member #1
    SEARCH works!
  7. #7 Re: HELP!**Fuel line replacement?**
    Minnesota
    Quote Originally Posted by Pepino View Post
    ^yes
    I have 110,000 on my car right now and it is my daily driver. I got the fuel line from a dealer even though I didn't want to. I could have gotten it cheaper off the internet but I need to get it installed before Sat because I am doing a top swap. I tried all the tips in that thread but I ended up beating the crap out of the filter and bending the fuel line. lol
  8. #8 Re: HELP!**Fuel line replacement?**
    Hillsborough, NJ
    Yes sir that's the tool. I believe its 3/8" (well at least on the ls motors) you'll need to use.
    Intensewhiplash.com
  1. Fluid cooline line replacement issue
    By Sabrewings in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-05-2013, 11:50 AM
  2. fuel line nut rusted to fuel line!!
    By Pepino in forum General Tech Discussion
    Last Post: 08-12-2010, 08:25 AM
  3. Fuel line to fuel filter cracked need help asap
    By Jays98GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-30-2010, 04:20 PM
  4. Custom AN Fuel Line setup for PRJ Fuel Rails... [*]
    By Iron Indian in forum How To Write-Ups/Tech Tips
    Last Post: 01-17-2009, 07:53 PM
  5. Parts are in for fuel line replacement
    By BlackGS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-09-2008, 10:00 AM
