Thread: Dome Lamp Disable Mode
Results 1 to 9 of 9
  1. #1 Dome Lamp Disable Mode
    Nov 2009
    Michigan
    My 2008 GP with sunroof has about six lamps on with a door open. The owner manual says that there are three modes to the dome switch. On/Off/Auto. I can hit the overhead switch and it seems to have only on/off. Can anyone find off/disable-automatic? Cleaning and detailing with the doors open is a real drain. This also means there is no stealth mode... Thanks.
  2. #2 Re: Dome Lamp Disable Mode
    GTX Level Member noreasonwhyy's Avatar
    Michigan
    pull teh interior fuse?
    97 GT - slow, rusty
    93 CTD - more slow, less rust
  3. #3 Re: Dome Lamp Disable Mode
    Mn
    You dont even need to pull the fuse. Just click the latch in the door with you finger. That will make it think the door is closed. Just remember to lift the handle to click it back befor you shut the door.
  4. #4 Re: Dome Lamp Disable Mode
    Charles City, IA
    pretty sure you can reprogram it with the driver information center.
    SMGPFC Two Nipple General
  5. #5 Re: Dome Lamp Disable Mode
    New Brunswick
    The off switch the manual mentions are only on models without sunroof and without roof console. There may be a way to configure it in the dic, I will have a look next time im in the car.
  6. #6 Re: Dome Lamp Disable Mode
    Pennsylvania
    Keep pressing the "i" on your DIC. You'll come across the lamp settings.
  7. #7 Re: Dome Lamp Disable Mode
    Charles City, IA
    Quote Originally Posted by SlowNA06 View Post
    I I sir.
  8. #8 Re: Dome Lamp Disable Mode
    Nov 2009
    Michigan
    i settings have many features but not one of them is disabling the dome lamps. If the no-sunroof models have a switch that does this function request to the BCM it looks like I need to find a way to emulate that. If you have such a switch what does it look/operate like? Three positions?
  9. #9 Re: Dome Lamp Disable Mode
    New Brunswick
    The switch is only in the dome itself, to the interior light you have a ground, constant positive, and a switched(by opeing the doors) positive.
    This way the ground is always the same, however when you shut the switch off none of the positives will make it to the bulb, when its on auto the switched positive is hooked to the bulb so when the door opens the light works, and when the on position is selected the constant positive is used to power the bulb.
    I would say the best thing is if you only need them off for detailing is to pull the fuse, however on mine they do shut off after 10 minutes of being on constantly without the engine running.
  1. How do you remove the backseat dome lamp housings?
    By salannelson in forum Audio, Security & Visual Electronics
    Last Post: 07-10-2010, 12:10 AM
  2. Dome light
    By Davisgtp in forum General Tech Discussion
    Last Post: 06-11-2010, 05:57 PM
  3. dome light
    By Davisgtp in forum Off Topic Discussion
    Last Post: 06-03-2010, 06:50 PM
  4. dome lights led?
    By Biggie1720 in forum Visual/Body Modifications
    Last Post: 05-04-2010, 09:26 AM
  5. Dome
    By abejjani4265 in forum General Tech Discussion
    Last Post: 03-26-2010, 07:33 AM
