symptoms are alt is only charging at 13.5 when i start the car and will drop to as low as 12.7 as the car runs long the speedometer is bouncing all over the place and my obd port and dic randomly works i suspect a bad ground as i just replaced the alt and had the batt load tested and it took a 300amp load also all the fuses are fine anyone have an idea
