Thread: 2001 Grand Prix SE w/3100-- A/c problem, clutch not engaging.
Results 1 to 3 of 3
  1. #1 2001 Grand Prix SE w/3100-- A/c problem, clutch not engaging.
    California
    I have a tough problem here:
    1) The "a/c" light comes on when you push the button on dash.
    2) all relays and diode are OK. (swaped and used DVM).
    3) The system is charged with feon.
    4) If i jumper the clutch relay the clutch engages- so the clutch is OK.
    5) There is NO (ZERO) 5 volt reference at the a/c pressure sensor.
    This 5 volts comes from the PCM (grey wire) and the same voltage supplies the MAP sensor and the a/c evap temp sensor.
    I would like to check to see if the 5 volts is present on the MAP and the Temp sensor but i don't know where they are. I need advice here. Also if there isn't 5 volts at all all 3 sensors that share this signal it might indicate a PCM problem. Where is the PCM on my car??--I looked behind glove box and in the air cleaner box? I would like to test the PCM for 5 volt output. Is there a good probe place? Is the PCM servicable? My next stop is the dealer if no one can help me. Thanks for reading my post.
  2. #2 Re: 2001 Grand Prix SE w/3100-- A/c problem, clutch not engaging.
    Welcome...try to move your post in the right section so it gets answered faster
  3. #3 Re: 2001 Grand Prix SE w/3100-- A/c problem, clutch not engaging.
    Becca Boo MizzBecca's Avatar
    Michigan
    welcome =)
    I drive a POS
  1. 02 grand prix 3100
    By spank127 in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-04-2009, 10:30 AM
  2. 2001 stock grand prix gt
    By grandprixgt in forum General Tech Discussion
    Last Post: 06-18-2009, 11:32 AM
  3. 2001 Grand Prix GT Upgrade
    By Goany in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-21-2009, 01:30 PM
  4. 2001 Grand Prix security?
    By neumjo in forum General Tech Discussion
    Last Post: 01-18-2009, 05:49 PM
