Thread: Hard startup and noise
Results 1 to 20 of 20
  1. #1 Re: Hard startup and noise
    Oklahoma
    Well, bell housing is not entirely correct, its the side cover rather. Sorry about that.
  2. #2 Re: Hard startup and noise
    GT Level Member GreenNirvana101's Avatar
    Feb 2008
    Wisco
    Alright I jacked 'er up and saw exactly what I need to do. I took a picture - so all I need to do is remove those two bolts that I circled? And then how do I re-wire it?
    I'm going to try to replace it this week.... where should I buy one? also - any advice from people who have done it before would be much appreciated. I'm pretty much a noob , so any help would be great!
    Former Camaro muscle and DSM turbo owner - now moving into the GTP Supercharged world!
    1997 GTP - STOCK.... for now
  3. #3 Re: Hard startup and noise
    Feb 2008
    Wisco
    Can anyone do a little write-up for me about how to replace a starter?
    I'm ordering one from Ed Morad.... not too shabby of a deal - $44.00
    a quick run down would be greatly appreciated, and worth some reputation
  4. #4 Re: Hard startup and noise
    I live here. UR LOSN's Avatar
    Rockford, IL
    Quote Originally Posted by GreenNirvana101 View Post
    Scott- you cant see it from here, but on the upper side of the starter is the solenoid. it has a positive/negative wire that can be disconnected by removing a nut(much like your alternator). Like Scotty had said...make sure you get them back on the right stud.....and that they DONT touch.
    there is no need to solder anything. I will give you a call today. just need to remove that plastic cover, remove 2 bolts, drop it down, remove 2 wires, put wires on new starter, put new starter up to bell housing, put 2 bolts back in. process is easy...just take your time.
  5. #5 Re: Hard startup and noise
    Feb 2008
    Wisco
    Alright - well today I was planning on replacing the starter, but ran into a few problems after taking it out and realizing its different than the one I got from Ed Morad.
    First off, I took out my core and brought it into advance auto to test it... it worked great, no problems at all. Advance said it should be fine, but they also said the one that I got from Morad was a different model as it was much shorter and looked a little different (Working on getting a refund from Morad).
    Advance said that the starter I have now should be fine... but it may need some shims? I bought a set of shims and tried my best trying a few different sizes (1/64, 1/32, 1/16).... it sounded better, but still was grinding/whining at startup....
    Can anyone tell me why I would still be getting this grinding noise? Has anyone used shims before on a GP? It says the starter doesn't need it... but idk. Any advice would be great! Thanks.
  6. #6 Re: Hard startup and noise
    Barksdale AFB, LA
    Did you try taking off the TC inspection cover and rotating the crank to inspect the flex plate? Maybe there is some damage to the teeth...
    2009 Subaru Impreza WRX STI
  7. #7 Re: Hard startup and noise
    Feb 2008
    Wisco
    there doesn't look like any damage to the teeth on the flywheel or the starter... but if I don't fix it... I'm guessing the grinding will end up damaging it...
    Are we supposed to use shims on these starters? Also - would a bad lower motor mount have any effect on this situation?
  1. growling noise
    By tjs84c10 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-13-2008, 02:06 AM
  2. weird noise
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-30-2008, 04:17 PM
  3. GTP Tranny Noise, Need Help
    By GTPGP98 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-28-2008, 05:08 PM
  4. Help!! '01 GTP misfiring/idiling rough at startup!!
    By fatride99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-06-2008, 06:20 PM
