Thread: PCM issue?
Results 1 to 8 of 8
ill12will8 PCM issue? 10-03-2010, 10:03 AM
Fivefingerdeathpunch Re: PCM issue? 10-03-2010, 10:58 AM
blueguy Re: PCM issue? 10-03-2010, 11:05 AM
FoSHO99 Re: PCM issue? 10-03-2010, 11:49 AM
ill12will8 Re: PCM issue? 10-03-2010, 11:42 AM
ill12will8 Re: PCM issue? 10-03-2010, 11:47 AM
Fivefingerdeathpunch Re: PCM issue? 10-03-2010, 11:48 AM
ill12will8 Re: PCM issue? 10-03-2010, 12:06 PM
  1. #1 PCM issue?
    GT Level Member ill12will8's Avatar
    DC/MD
    I was practicing taking apart the stock airbox because I will be making my intake this weekend and i pulled out the pcm and noticed something wierd.
    See it says "1999 Grand Prix" but i own a 2000. Is this ok oor should i be worried?
    1997 Artic White GTP: Stock (I call her "Brooke")
    2000 Silvermist GTP: ZZP DP, CAI w/ 9" open cone, Dorman front sway bar, PEMs, AL605 -DEAD & GONE
  2. #2 Re: PCM issue?
    your fine
  3. #3 Re: PCM issue?
    I'd be more worried about the 3100 marked on there than anything.
  4. #4 Re: PCM issue?
    Jan 1970
    Maquoketa, Iowa
    https://spreadsheets.google.com/pub?...=0&output=html
    09361735 pcm's went in most 99's and also in 2000 gtps. You can interchange a lot of them through the years 98-02.
    What probably happened was someone swapped it out and flashed that pcm with a 00 gtp file and probably updated your vin.
  5. #5 Re: PCM issue?
    DC/MD
    so what should i do about that blue
  6. #6 Re: PCM issue?
    DC/MD
    would this have anything to do with me not being able to scan it? my uncle just tried to scan it but nothin came up (we're sure its working because he just finished using it on his car)
  7. #7 Re: PCM issue?
    maybe you cig lighter fuse is blown, that can cause the OBD2 port to not work. i think
  8. #8 Re: PCM issue?
    DC/MD
    yea my cig lighter is out so ill check that and would someone flash the pcm stock or is it possible they tuned it
  1. NEED SOME HELP...possible map issue?
    By 01gpgt01 in forum General Tech Discussion
    Last Post: 07-20-2010, 06:10 PM
  2. ABS Issue
    By m1sterb0b in forum Brakes/Suspension/Chassis
    Last Post: 11-03-2009, 04:42 PM
  3. another kr issue
    Last Post: 02-24-2009, 12:30 PM
  4. GTP pcm issue with ZZP
    By Regalgs98 in forum PCM Tuning
    Last Post: 02-18-2009, 02:16 AM
  5. Help with this issue please
    By TDCRacing in forum General Tech Discussion
    Last Post: 07-05-2008, 05:00 PM
