Thread: NEED SOME HELP...possible map issue?
Results 1 to 5 of 5
  1. #1 NEED SOME HELP...possible map issue?
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    I was getting 16.4lfts at idle, and low speed cruse and deceleration. I found a vac leak at the LIM to EGR tube where it meets the EGR(the tube was cracked in half). I replaced the tube and Bingo no more Idle 16.4lfts or slow cruise Pegged LFTS, But anytime I'm cruising and off the LFTS peg. If I coast to a stop the Lfts go to a more normal value as soon as I hit Idle and stopped. Im attaching some scans to better understand whats going on. I'm thinking maybe a map issue? Ive also noticed that when the lftS peg the timing is ALWAYS 16.0 degrees. Only known issue is that the EGR pipe that meets at the header has a exhaust leak. (Small)
    NannyLog(05.12.2010_16.22.34). from GPGT01 -- Scan Depot dot net This is a cruise that I let off the gas and the car coasted to a stop and idled.
    NannyLog(05.12.2010_16.18.24). from GPGT01 -- Scan Depot dot net This one Im slightly accelerating and letting off to cruise and then accelerating repeatedly.
    NannyLog(05.09.2010_01.01.08). from GPGT01 -- Scan Depot dot net WOT Pull (starts in 2nd gear around 40-50 mph and goes to 100mph or so. (before vac leak was fixed)
    Thanks for looking and any ideas on the issue are appreciated. Thanks
    _____________________________
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  2. #2 Re: NEED SOME HELP...possible map issue?
    Hagerstown,Md
    EGR to header leak gone.Put in a new map.....Still getting 16.4LFT's when i let off the gas..lFT's are fine at idle. IAC's in the 50's so no vac leak
    And still tossing a p1133 code
  3. #3 Re: NEED SOME HELP...possible map issue?
    Hagerstown,Md
    I failed emissions because I cleared the code and ran the car for awhile went in and got the not ready fail....Im seriously thinking of selling the car. I cant figure this out. Ive replaced the 02 Ive sealed all exhaust leaks. Ive changed the 02 extension.
  4. #4 Re: NEED SOME HELP...possible map issue?
    dont sell it, its not worth it to get rid of it, im sure others on here can maybe help you out.
  5. #5 Re: NEED SOME HELP...possible map issue?
    Hagerstown,Md
    Welp im deleting the code setting it on number 3 ses is checked. I hope ill still run the tests so i can pass emissions setting it like this
  1. MAF Issue
    By prostallion347 in forum General Tech Discussion
    Last Post: 03-30-2010, 11:36 AM
  2. Another DiC issue
    By Wolf79 in forum General Tech Discussion
    Last Post: 02-17-2010, 02:53 PM
  3. GTP pcm issue with ZZP
    By Regalgs98 in forum PCM Tuning
    Last Post: 02-18-2009, 02:16 AM
  4. I have a big issue please help me
    By Goany in forum General Tech Discussion
    Last Post: 12-02-2008, 02:51 PM
  5. Help with this issue please
    By TDCRacing in forum General Tech Discussion
    Last Post: 07-05-2008, 05:00 PM
