Thread: False boost
Results 1 to 7 of 7
  1. #1 False boost
    Tawas
    Like before my car will randomly show false boost, some times it will show boost when i first start the car(usually cooler days) i checked and my BBV is working right, and i just replaced the vac line set(that's what i thought it was),and when it does it idles high. has anyone seen this before, it's a series 2 by the way.
  2. #2 Re: False boost
    are you reading that off the DIC boost meter with the bars?
    or do you have a REAL boost gauge?
    I would get a real boost gauge that shows you VAC and BOOST, that way you know whats really going on.
  3. #3 Re: False boost
    Tawas
    i'm just reading off the DIC, I know there is something wrong but i can't figure out what, this is my bone stock daily driver so i really need to figure this out.
  4. #4 Re: False boost
    Charles City, IA
    Probably have a vac leak.
    SMGPFC Two Nipple General
  5. #5 Re: False boost
    Tawas
    How do i know where it is, what's a good way to test for that. it just seams wierd that a vac leak would be random like that.
  6. #6 Re: False boost
    GT Level Member Deviq's Avatar
    SE WI
    I've never done it but ppl around here say to spray carb cleaner towards the vac lines. If you car starts revving up, you've found your leak.
    Quote Originally Posted by zildjian102
    .. friggin trashy people. I did stuff with their daughter
  7. #7 Re: False boost
    Charles City, IA
    ^ that.
  1. FALSE KR/ poly mounts
    Last Post: 05-10-2016, 03:30 PM
  2. False ABS engagement...no abs light
    By eman84 in forum Brakes/Suspension/Chassis
    Last Post: 03-16-2010, 06:17 PM
  3. false knock?
    Last Post: 08-20-2009, 09:21 PM
  4. False Advertisement
    By Wadeb79 in forum Off Topic Discussion
    Last Post: 07-13-2009, 05:34 PM
  5. False Alarms
    By RichCresci in forum General Tech Discussion
    Last Post: 12-11-2008, 01:06 PM
