Thread: Car won't do anything when key is turned in ignition
Results 1 to 6 of 6
  1. #1 Car won't do anything when key is turned in ignition
    Jul 2010
    Niles, MI
    I have a 97 GTP that a couple months ago had the parking lights on but the lights were off so it drained my battery but after a charge everything was fine. Well now the other night when I put key in ignition it does the dinging and the battery, gas, temp and other helper lights turn on but as soon as I go to turn it over the power is gone totally. Has this happened to anyone else and can anyone help? Thanks
  2. #2 Re: Car won't do anything when key is turned in ignition
    GT Level Member MBruneaux's Avatar
    Canterbury, CT
    Quote Originally Posted by LJr22 View Post
    Start with checking the battery connections, make sure they are clean, if they are clean then I would start with a new battery.
    2001 Grand Prix GTP - Daily Driver12" front brake upgrade ('05 Monte), Raptor tune, Open cone, Front and rear strut tower braces, SS brake hoses, BMR trailing arms, ZZP 3" catted downpipe, Dorman front sway bar, GMPP rear sway bar, solid trans and engine mount, flipped dog bones and Borla exhaust.
  3. #3 Re: Car won't do anything when key is turned in ignition
    Jul 2010
    Niles, MI
    Thanks for the quick reply. I just replaced the battery between 1-2 years ago do you think it could be bad that quick? Thanks
  4. #4 Re: Car won't do anything when key is turned in ignition
    SE Level Member SteveCZ28's Avatar
    Dec 2010
    Greene,Ia
    x2 on new battery...when you drain one to completly dead like you did in your case with the lights, it drastically reduces the life of a battery
    1999 Camaro Z28
    1997 Grand Prix GTP
    1995 Dodge Ram
  5. #5 Re: Car won't do anything when key is turned in ignition
    Jul 2010
    Niles, MI
    Ok thanks for the help it is greatly appreciated will do the new battery
  6. #6 Re: Car won't do anything when key is turned in ignition
    Canterbury, CT
    Batteries can die whenever they want, I've seen batteries last two years or like the one in my Trans Am lasted 7. Interstates are the best.
  1. Can drilled and slotted rotors be turned?
    By corsagtp in forum Brakes/Suspension/Chassis
    Last Post: 04-11-2010, 01:55 AM
  2. HUD turned metric!
    By foghelmut in forum General Tech Discussion
    Last Post: 07-19-2009, 11:27 PM
  3. just turned 18! sick!
    By 2000GTP in forum Off Topic Discussion
    Last Post: 06-30-2009, 08:04 PM
  4. Air condition/vents smell when turned on! How do I fix?
    By Freebeer187 in forum General Tech Discussion
    Last Post: 08-08-2008, 12:54 PM
