Thread: converter?
Results 1 to 14 of 14
  1. #1 converter?
    SE Level Member timmysgtp's Avatar
    Jul 2010
    marrero louisiana
    if I put headers without a cat I know it will throw a code but can I ride around for a while without a tune? How bad will it hurt?
  2. #2 Re: converter?
    Jul 2010
    marrero louisiana
    nobody has any insite??
  3. #3 Re: converter?
    Delaware, OH
    MPG will go to **** and you'll foul the plugs out sooner but it won't kill it if you do it for a little while
    No More GTP for me.
    2014 Chevy Cruze ECO Manual. 40+MPG
  4. #4 Re: converter?
    use your stock cat.
  5. #5 Re: converter?
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    Quote Originally Posted by benner View Post
    MPG will go to ****
    no it wont. the rear o2 sensor, the one that will be picking up and throwing the code, will not alter air/fuel ratios.
    i drove around 4 months with no cat, and a CEL to go with it, and neither my city or highway mpgs were affected.
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  6. #6 Re: converter?
    Jul 2010
    marrero louisiana
    stock cat is gettin a lil backed up I think my mpgs are only right at 20 right now I guess imma go ahed and get a magnaflow cat
  7. #7 Re: converter?
    Jul 2010
    marrero louisiana
    anyone know where I can pick up a cheap cat that will bolt right up into some speed daddy headers?
  8. #8 Re: converter?
    Donating Users Vegas_Matt's Avatar
    Jul 2010
    Las Vegas, NV
    all cats are usable with headers. you just have to make sure the pipe sizing is right. have you installed the speeddaddy's yet? and what year is your car?
    <MiZzBeCcA>its not rape if you yell suprise
  9. #9 Re: converter?
    Jul 2010
    marrero louisiana
    no I haven't will next weekend! It's a 2002 gtp
  10. #10 Re: converter?
    Jul 2010
    Las Vegas, NV
    Ya? That's cool. But just order a cat and have it welded on...
  11. #11 Re: converter?
    Jul 2010
    marrero louisiana
    any ideas on a place 2 order a good priced on?
  12. #12 Re: converter?
    Willoughby, Ohio
    ZZ Performance
    you can select the 3inch option for the headers
  13. #13 Re: converter?
    Jul 2010
    Las Vegas, NV
    I have a catalyst ineficiency. Code and my air/fuel is maces out...
  14. #14 Re: converter?
    Donating Users
    South Deerfield, MA
    You will get the catalyst efficiency code if the rear O2 sensor is there and the cat is gone. If you remove the rear O2 sensor, that is where you will end up running rich in the 01+.
    2002 GTP: GMPP Sway Bars, BMR trailing arms, KYB AGX/Vogtlands, 12" brake upgrade
    Modified SSAC headers, K&N Intake, 3.4 MPS, S1X, Gen V, 104's, HPTuned.
  1. Cat Converter
    By VGPGT in forum General Tech Discussion
    Last Post: 08-30-2010, 02:20 AM
  2. Converter I.D.
    By charlie31603 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-12-2010, 03:17 PM
  3. Catalytic Converter
    By LonelyLoser45 in forum General Tech Discussion
    Last Post: 04-17-2009, 12:24 PM
  4. 04 cat converter.
    By rcweldon988 in forum 04+ Specifics
    Last Post: 02-18-2009, 08:21 AM
  5. bad converter again
    By shawn in forum General Tech Discussion
    Last Post: 02-16-2009, 03:11 PM
