Thread: rear o2 sensor
Results 1 to 3 of 3
  1. #1 rear o2 sensor
    SE Level Member timmysgtp's Avatar
    Jul 2010
    marrero louisiana
    does the rear o2 sensor effect air/fuel ratio? Reason I'm asking is because I've had people tell me that when I throw a code because of no cat that the rear o2 does not effect my air/fuel ratio! Is this true
  2. #2 Re: rear o2 sensor
    Donating Users Vegas_Matt's Avatar
    Jul 2010
    Las Vegas, NV
    I've heard both things too. First is that only the front tells you the afr. Then others mention a diagnostic in 01+ grand prixs where it runs rich and the second o2 has to read rich to get it to stop. I'm getting a catalyst inefficicency code right now and my air:fuel is locked at 14.7:1
    <MiZzBeCcA>its not rape if you yell suprise
  3. #3 Re: rear o2 sensor
    Donating Users
    South Deerfield, MA
    ^^this. The O2 after the cat is just to monitor the catalyst efficiency. On the 01+, it will do a diagnostic test that if there is no response, it will run really rich.
    2002 GTP: GMPP Sway Bars, BMR trailing arms, KYB AGX/Vogtlands, 12" brake upgrade
    Modified SSAC headers, K&N Intake, 3.4 MPS, S1X, Gen V, 104's, HPTuned.
  1. rear o2 sensor
    By boostedgtp2003 in forum General Tech Discussion
    Last Post: 04-09-2010, 09:41 PM
  2. Help! Rear knock sensor
    By cav in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-26-2010, 12:26 PM
  3. Rear Knock sensor P0332
    By cav in forum Introductions/Noob Questions
    Last Post: 03-26-2010, 07:51 AM
  4. Removing rear O2 sensor
    By Black18Ice in forum General Tech Discussion
    Last Post: 11-06-2009, 02:51 PM
  5. rear o2 sensor
    Last Post: 02-22-2009, 08:53 AM
