Thread: 98 gtp wierd noises n running hot.
Results 1 to 14 of 14
  1. #1 98 gtp wierd noises n running hot.
    SE Level Member kurt5153's Avatar
    Apple Valley,Ca 92308
    okay so yesterday i got a 98 gtp with 144k. n i noticed that up top there is a metal clinking/roaring sound. kinda leaning towards the s/c since the guy didn't know when it was serviced last, or the heads are bad.also its running close to 210 when im just sitting but does't go any higher but goes down when im moving. plus the low coolant light is on but it is full. the light comes n goes. looking for some help please
  2. #2 Re: 98 gtp wierd noises n running hot.
    is it kinda like a rattle sound? If so the coupler is bad in the supercharger. Its a pretty easy fix, and only cost around 50 bucks to do it yourself.
  3. #3 Re: 98 gtp wierd noises n running hot.
    yep that sounds like it! is there a how to on here you can point me to n thxs!
  4. #4 Re: 98 gtp wierd noises n running hot.
    here watch this: YouTube - Replacing a worn out supercharger coupler on 3.8 GM engines
    and here is the coupler: ZZ Performance
    you have the option to buy the oil with the coupler, or you can just run the local dealership and ask for 2 bottles.
  5. #5 Re: 98 gtp wierd noises n running hot.
    sweet thanks! is it normal for them to run that hot?
  6. #6 Re: 98 gtp wierd noises n running hot.
    also seems like a good time for a pulley!
  7. #7 Re: 98 gtp wierd noises n running hot.
    Quote Originally Posted by kurt5153 View Post
    no. you must have supporting mods to run a smaller pulley.
    Read this. It will tell you just about everything you will need to know to mod the car safe.
    http://www.grandprixforums.net/safel...car-17482.html
  8. #8 Re: 98 gtp wierd noises n running hot.
    ya ive read that, gonna do headers down pipe n cat back n cai at the same time, just need a tune right?
  9. #9 Re: 98 gtp wierd noises n running hot.
    headers have a downpipe, so need to buy one.
    get autolite 104's for plugs
    open cone
    pulley 3.4
    if it was me a catback is a waste, these cars dont realyy sound good with exhuast IMO. They drone alot with aftermarket mufflers.
    if you get header your stock exhaust will wake up quite a bit and will sound alot better.
    as for a tune, contact REPTILE on this site, he can get you a custom tune for application and he is very good at what he does and is cheaper than a canned tune.
  10. #10 Re: 98 gtp wierd noises n running hot.
    open cone
    so i do need a dp?
    what do you mean by open cone?
    car came with flowmasters on stock cat back
  11. #11 Re: 98 gtp wierd noises n running hot.
    no, Headers have everything you need, they come with the front and rear header, crossover pipe and downpipe.
    open cone, is a air filter. I am saying go open cone and put it right on the end of your TB to save you money. There is no sense in buy a cold air kit, because the amount of HP they say that it will increase in your car is false. Hot air or cold air it really does not matter. The blower is gunna superheat that air anyway before it goes into the engine.
    Open cone is cheap, effective and most of all the best way to make the blower whine like no tomorrow.
    and just keep the exhaust the way it is, with the headers it will make it better.
  12. #12 Re: 98 gtp wierd noises n running hot.
    k sounds good but what do i do about that sensor in the intake tube?
  13. #13 Re: 98 gtp wierd noises n running hot.
    go to home depot or lowes and get a 3 in. rubber coupler and put that on the TB drill a hole for the sensor and put the open cone on the other end of the coupler.
    or just zip tie it next to the air filter.
  14. #14 Re: 98 gtp wierd noises n running hot.
    k thxs for the help, got anything on the high temp?
  1. My car is making bad noises!!!!
    By boostedgtp13 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-03-2010, 12:20 AM
  2. Front end noises
    By kayza in forum General Tech Discussion
    Last Post: 05-31-2010, 08:35 AM
  3. Various noises my car shouldn't be making
    By matt5112 in forum General Tech Discussion
    Last Post: 11-19-2009, 07:24 AM
  4. Random Sub noises
    By stoner17971 in forum Audio, Security & Visual Electronics
    Last Post: 07-07-2009, 04:56 AM
  5. K&N Air Intake noises
    By zofsharick@gmail.com in forum General Tech Discussion
    Last Post: 10-19-2008, 09:07 PM
