Thread: Seatbelt light
Results 1 to 2 of 2
  1. #1 Seatbelt light
    SE Level Member SoniqBoost's Avatar
    Denton, TX
    For about 4 days now, my seatbelt light doesn't turn off when I latch my seatbelt after I start the car. It keeps flashing (for 30 seconds I assume) as if I hadn't put my seatbelt on.
    I'm guessing there's some sort of sensor in the latch, then wires that feed somewhere, blah blah...but what I'm wondering is whether someone has had this problem before. I can't imagine it would cause any problems, but it sure is annoying...
    2006 Grand Prix GT
  2. #2 Re: Seatbelt light
    GTP Level Member SuperSport's Avatar
    Michigan
    Unless your area has car inspection, i would just remove the bulb from the cluster. Thats probably easier and safer than messing with the seatbelt latch and possibly not securing it back properly if you do change it...
    2001 Grand Prix GT Coupe
    Comp G Wheels - SS Corners - Infinity Sound - Tint - Digital DIC Swap - 893 Fogs
  1. How to disable seatbelt warning chime?
    By mrhdv in forum General Tech Discussion
    Last Post: 07-19-2010, 10:16 AM
  2. Replies: 16
    Last Post: 01-23-2010, 09:43 AM
  3. Seatbelt bolt?
    By jasonball in forum 04+ Specifics
    Last Post: 03-03-2009, 12:24 AM
