Thread: Help witk kr
Results 1 to 20 of 24
  1. #1 Re: Help witk kr
    GT Level Member rolyat's Avatar
    OKC
    a lot of things should be watched and referenced, which you cant do with an aeroforce.
    Alright got ya. I didn't think I could do anything that in depth with it...
    2000 GTP: autolite 104's, 180 t-stat, shift kit, open cone spectre, 1.9 rockers, polished TB, ported blower, SD headers, zzp mps/3.4 pulley, 42.5lbs injectors, Reptile tune
  2. #2 Re: Help witk kr
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Quote Originally Posted by rolyat View Post
    See if you can find someone that can scan and log a file for you. We could figure it out quickly. Could be a tune issue, could be a mecanical issue. Hard to tell. A scan would go along ways
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  3. #3 Re: Help witk kr
    OKC
    I guess I might just have to try finding someone with a scanner then... do you know where I should look?
    I don't think it's a tune issue though. It had excessive kr before I got my current tune. The odds of the factory tune and Brian's tune causing this much kr is unlikely.
  4. #4 Re: Help witk kr
    OKC
    Well I took it for another drive... I took one wot run when the engine was just warm ( around 165-170*F) and it had absolutely zero knock! Is there a certain temperature the coolant needs to be before the knock sensor starts working?
    After it got up to operating temperature, I took it for a wot run all the way up to 100mph and I got a 10.5* kr spike
    Well needless to say, no more flooring it till I get it fixed...
    What kind of scanner or software do I need to have it scanned with? HPtuner, DHP, Techforce, Snap-On scanner, or what?
    I'm thinking about just replacing the fuel pump and hoping for the best...
  5. #5 Re: Help witk kr
    OKC
    What kind of scanner/software do I need to find?
  6. #6 Re: Help witk kr
    OKC
    TTT
  7. #7 Re: Help witk kr
    OKC
    TTT
    I guess it's a retarded question.... but seriously, what do I need to have it scanned with to get a log on here?
