Thread: Harmonic, Balancer, Crankshaft, Sensor
Results 1 to 13 of 13
  1. #1 Harmonic, Balancer, Crankshaft, Sensor
    Flint, MI
    Upon replacing my crankshaft position sensor (code came up), I realized the harmonic balancer was installed approximately 20 degrees off. Curious what problems would be expected with the balancer off 20 degrees?
    2003 GTP
    Engine is 1999 from Junkyard
  2. #2 Re: Harmonic, Balancer, Crankshaft, Sensor
    it can't be installed 20* off unless someone put another hole in it for the crank key.
  3. #3 Re: Harmonic, Balancer, Crankshaft, Sensor
    Flint, MI
    It appears that the crank key itself made another slot in the balancer, it was ugly, trust me. The key was slammed deep into the crank. and there was a "new" slot in the balancer, like I said approximately 20degrees or so from the clear original. I am guessing they got it started (wrong) then used the huge crank bolt to reef it on?
  4. #4 Re: Harmonic, Balancer, Crankshaft, Sensor
    Nov 2009
    Grand haven
    I am hearing what you are saying but matt is right. I would have to see a pix of this.
  5. #5 Re: Harmonic, Balancer, Crankshaft, Sensor
    Flint, MI
    I am not taking it back off to take an image of it, it was clearly smashed on incorrectly approximately 20* off from where it should have been.
    Imagine leaving the key out, and shoving the balancer on 20* off.
    There seem to be many changes in the way it runs now, curious what this could/would have effected?
  6. #6 Re: Harmonic, Balancer, Crankshaft, Sensor
    The balance of the engine.
  7. #7 Re: Harmonic, Balancer, Crankshaft, Sensor
    Donating Users alkygto's Avatar
    Nov 2009
    wentzville
    Could the outer ring have slipped on the hub? I'm not real familiar with the 3800 balancer (yet. lol) but most have a rubber ring between the hub and outer ring and it could have slipped.
    As far as the crank goes, has the motor ever been out of the car before you bought it?
    1997 Pontiac Grand Prix GTP
    1969 Pontiac GTO
  8. #8 Re: Harmonic, Balancer, Crankshaft, Sensor
    Flint, MI
    The balance of the engine does seem to have improved, as it idles smoother now.
    I am more curious about the effect of the crankshaft sensor and it telling the computer what position the crank is in being 20* off.
    Also, under boost this engine always made a rattly noise, I always assumed it was a bad coupler in the SC but since the new Crank sensor and harmonic balancer adjustment, the noise is completely gone.
    alkygto - I bought this engine from a junkyard, its a 1999 L67, car is 2003.
  9. #9 Re: Harmonic, Balancer, Crankshaft, Sensor
    It would make it run like epic crap...had this issue once...put on a new balancer...problem solved. It throws the timing of the engine rotating assembly off 20*...which...isn't good. I know what your talking about man...sorry to hear in the beginning, but glad you got it fixed.
  10. #10 Re: Harmonic, Balancer, Crankshaft, Sensor
    I've seen this a few times. Still wonder...how anyone can do this...really. To put a balancer on you push it forward and rotate it until it catches the keyway. Then you tighten the bolt to spec.
    It seems to happen way to often to way too many people... please explain to me how this happened. My brain can't quite comprehend it.
  11. #11 Re: Harmonic, Balancer, Crankshaft, Sensor
    Charles City, IA
    People having impacts that are retarded.
    SMGPFC Two Nipple General
  12. #12 Re: Harmonic, Balancer, Crankshaft, Sensor
  13. #13 Re: Harmonic, Balancer, Crankshaft, Sensor
    Flint, MI
    BillBoost37 - I bought it from the junkyard that way. It ran pretty decent too, idled rough, cleared up when on the throttle.
    Now it idles awesome in park, or when on the brake, but when you take your foot off the brake, seems to putput...(for lack of a better description) Have no idea why.
  1. How do you get the crank pulley/harmonic balancer off???
    By comongoose in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-12-2011, 11:08 PM
  2. Harmonic balancer puller
    By TorqueAutoMotiv in forum Shops and Community Heroes
    Last Post: 10-02-2010, 03:49 AM
  3. Harmonic balancer question
    By drewz313 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-11-2009, 04:52 PM
  4. Any advice removing old harmonic balancer?
    By 99prixgt in forum General Tech Discussion
    Last Post: 05-09-2009, 06:35 PM
