Thread: Pass Side floor wet...
Results 1 to 9 of 9
  1. #1 Pass Side floor wet...
    Stouffville, ON
    Been doing this for a while, it's time to fix it before winter!
    The passenger side front floors are getting wet, where is the first place I should be looking? They will dry out sometimes real well, then next thing you know, soaked. AC doesn't work in my car if it makes a difference...
    01 GTP 4 door
    Thanks guys
  2. #2 Re: Pass Side floor wet...
    Charles City, IA
    Read the water in floor board perminate fix thread in the how to. Then try a search next time.
    SMGPFC Two Nipple General
  3. #3 Re: Pass Side floor wet...
    Willoughby, Ohio
    ^^^ yup, its an easy fix
  4. #4 Re: Pass Side floor wet...
    GTP Level Member lambokit's Avatar
    Apr 2009
    Radford, Virginia
    The Search is always your best friend. And yes, it is an easy fix...
    Lambokit to be built!!!!!
  5. #5 Re: Pass Side floor wet...
    Stouffville, ON
    thanks.
  6. #6 Re: Pass Side floor wet...
    GTX Level Member Biohazed's Avatar
    Philadelphia, Pennsylvania, United States
    yup all it is the part to fix it is only a few bucks as well so its def worth doing it lol
    *image too tall*
    BMR F + R Strut Bars - Falken Torque V 18's - JVC S900 - Kicker C10's - Spyder Projectors, Wizaird,
  7. #7 Re: Pass Side floor wet...
    Jul 2012
    Kalamazoo, MI
    why can't anybody just answer the question and quit telling people where they should look??? everything i read deals with "cowl"....where is the stupid evaporator drain hose??? how about a diagram or something simple? thanks
  8. #8 Re: Pass Side floor wet...
    GT Level Member atj8's Avatar
    Midwest
    calm down there buddy we are all here to help each other out....this just happened to me this week. are u getting water while the car is parked? if so go read this http://www.grandprixforums.net/water...-fix-6961.html ,,,,,,but ur drain hose is underneath the dashboard, there is what is called the AC evaporator case. This case has a drain tube. It is a small little hose that goes from the case through your firewall out the bottom of the car..
  9. #9 Re: Pass Side floor wet...
    St. Louis
    After 2 years I would think the OP figured out ,lol.. And the reason this isn't answered is because its a common issue, hence the sticky. If once you read the info and you still have questions, then post up your own new thread and we can help. All else fails get an HVAC manual for your car, it should have a diagram of it there.
  1. 97-03 GP pass. floor wet
    By Street Dreams CC in forum General Tech Discussion
    Last Post: 10-10-2018, 09:56 PM
  2. Carpet very wet on drivers side floor
    By magician1979 in forum General Tech Discussion
    Last Post: 10-26-2009, 03:18 PM
  3. Water on passenger side floor PLEASE HeLP
    By NightriderGT2000 in forum General Tech Discussion
    Last Post: 01-17-2009, 10:45 PM
  4. Ac dripping into passenger side floor.
    By azzkikr1957 in forum General Tech Discussion
    Last Post: 06-15-2008, 10:24 AM
