Thread: noisy power steering pump?
Results 1 to 6 of 6
  1. #1 Re: noisy power steering pump?
    PA
    I would suggest the same thing as alky. On my wife's 3.1 malibu, the pump was noisy. So I sucked out the fluid and put new in. Let it mix for a couple days, and did it again. Repeated this till the fluid was all new, and never had an issue since. And used less than a quart of fluid.
    2001 GSE
  2. #2 Re: noisy power steering pump?
    SE Level Member Teardrop's Avatar
    Indiana
    Appreciate that, I am gonna have to change it I guess.
    If it is not a big hassle, I might disconnect a power steering line at the cooler and let it drain thru there. I guess the worst that will happen is it won't help.
    I know how to bleed it and all so let me try that, thanks again and I shall update when done.
    EDIT -
    So I used a turkey baster to remove the PS fluid, started engine, got some more in the reservoir, removed, filled it up, bled the system, and then did the extraction again.
    The pump can still be heard when I am turning the wheel but otherwise it seemed to have quieted down.
    And yeah, the old fluid was worse than I originally thought, it was yellow and the new fluid was clear.
    94 Grand Prix GTP, 3.4
  1. power steering pump
    By indyal in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-18-2009, 04:26 PM
  2. Power steering pump noise
    By minichopper6hp in forum General Tech Discussion
    Last Post: 07-18-2009, 01:57 AM
  3. power steering pump question
    By kjohnson in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-17-2009, 10:30 PM
  4. Power steering pump mystery
    By cidknee in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-21-2009, 09:50 PM
  5. Power Steering pump
    By airhead in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-15-2008, 07:16 AM
