Thread: throttle body screen
Results 1 to 13 of 13
  1. #1 throttle body screen
    bc canada
    Well i got a call from the gm dealer today about why my gp was starting then stalling and they asked where the screen was for the throttlebody, according to them the air turbulence will cause it to run rich and throw the airfuel ratio wacko. should I believe them?
  2. #2 Re: throttle body screen
    it does cause idling issues on some cars. its hit or miss.
  3. #3 Re: throttle body screen
    Charles City, IA
    Yeah they are probably right.
    SMGPFC Two Nipple General
  4. #4 Re: throttle body screen
    I live here. TLSheff's Avatar
    Quote Originally Posted by danamn6677 View Post
    ...according to them the air turbulence will cause it to run rich and throw the airfuel ratio wacko...
    Mine has a slightly rough idle with the stock air tube on it and no screen, but still runs fine under throttle. if you just removed the screen may consider putting it back on until you get an intake with a smooth tube. Alot of people have removed the screen with no problems, but i think they all did the smooth intake.
    if all else, put the screen back on, start it, let it warm up and if it has a rough idle still you know its something else
  5. #5 Re: throttle body screen
    bc canada
    its $105 for the screen and snapring, wreckers around here will not sell it without selling the throttlebody for 300.
  6. #6 Re: throttle body screen
    Kansas
    Wow.. look here for one for like 5 bucks
    SOLD 1999 GT Silvermist TS
  7. #7 Re: throttle body screen
    Jul 2010
    Outside ATL
    Quote Originally Posted by Gafford44 View Post
    look where?
  8. #8 Re: throttle body screen
  9. #9 Re: throttle body screen
    SE Level Member Phantom's Avatar
    Independence KY
    You could just go to an auto parts store and get a CAI tube with a 45-70 degree bend for $50-60 and a rubber pipe adaptor for $3.50 that I is think 3" and try that. It worked on mt L36 TB with a screen and has had no problem with the ported L67 TB without the screen as I forgot to put it back in.
  10. #10 Re: throttle body screen
    bc canada
    I have a open element air filter on the car but when I took it to the dealer they had a GP on the lot so I tried the screen on mine and it smoothed it out and started alot better. so since no wrecking yard will sell me just the screen without the entire TB I had to order it through GM.
    You know its kind of funny it started happening when I moved to BC from Manitoba...
  11. #11 Re: throttle body screen
    bc canada
    well I got my screen installed and all the stalling and rough idle are now gone
    Cost: $88
    Now on to the intake gaskets thatll be $600 for both upper and lowers.
  12. #12 Re: throttle body screen
    should have just gone to a u-pull it yard and put it in your pocket along with the snap ring.
  13. #13 Re: throttle body screen
    bc canada
    I wish it was that easy the workers escorted me in to the yards.
  1. Removing throttle screen?
    By NewPrixOwner666 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-15-2010, 02:56 PM
  2. throttle body screen
    Last Post: 11-08-2008, 08:46 PM
  3. Can I remove the throttle body screen??
    By TDCRacing in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-09-2008, 09:00 AM
