there's a little button underneath the steering column you can push with a screw driver after you get the cap off. It'll let your key come out. Easiest way to fix it is to zip tie the button down. Mine's worked great for over a year now. If I recall correctly, three torx screws gets the lower half of the cover off.
...otherwise you replace the solenoid....
