Hey guys! thanks for all the info. I tried a lil of everything and still kept coming up with (sit for a few hours, disconnect battery, unplug MAF and IAC, reconnect battery, car start right up) same scenario. Been had a lot going on in last couple of weeks (since Fri. 13th, go figure) so I finally gave up and took it to Phillips Car Care and had it diagnosed. $239.00 later problem was found to be IGNITION CONTROL MODULE. Had it replaced and now purring like a kitten. My thing is now I just replaced that module approx. 6 mos. ago. I'm going to check into the warranty info on it in the morning. However, I did realize that I failed to apply the supplied THERMAL GREASE to back plate when I installed it which I assume could've contributed to its premature failure. Anyway like I said problem was ICM. I thank you all for the replies and help. I look forward to chatting witcha later!
