Thread: 97 Grand prix won't start... Need help... BAD...
Results 1 to 2 of 2
  1. #1 97 Grand prix won't start... Need help... BAD...
    New Sharon IA
    97 grand prix gt wont start... My wifes been driving it for awhile now and she told me it wasn't wanting to start at all, So I go out and look at the car and i turn the key and it starts... Next morning I come out and turn the key and nothing... the lights and radio come on but the starter isn't cranking... I put a new starter on it now and it still isn't doing anything... What do i need to check to find this problem? Any help would be great..
  2. #2 Re: 97 Grand prix won't start... Need help... BAD...
    Wausau, WI
    check the battery......if you can jump it, get the alternator tested to see if it is working properly. If you have proper voltages from everything you might want to look into the crank position sensor, fuel pump, MAF or IAC. Check the voltages on everything, make sure the grounds are all tight and let us know if it fixes it or if you need further direction. If you get it running take it to autozone or someplace else that will check your alternator. Keep us posted. I would def start by checking the batt/alt first.
  1. 97 Grand prix won't start... Need help... BAD...
    By 98gtxking in forum General Tech Discussion
    Last Post: 10-08-2009, 10:50 PM
  2. 96 grand prix 3.1 wont start cold
    By oldtruckluvr in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-17-2009, 08:51 AM
  3. 1999 Grand Prix sometimes won't start
    By sabram in forum Canada
    Last Post: 09-13-2009, 07:31 PM
  4. 2001 Grand AM 3.4 engine will not start
    By cvbaker in forum General Tech Discussion
    Last Post: 03-12-2009, 01:03 AM
  5. Grand Prix newb with a start off question
    By PontiacBoy13 in forum Introductions/Noob Questions
    Last Post: 08-24-2008, 08:16 PM
