Thread: m90 rebuild
Results 1 to 15 of 15
  1. #1 Re: m90 rebuild
    Mn
    Finally had time to look at my case and still cant figure out a good way to get the bearings out? Its a gen 5 2004. Need to get it done soon because the motor is almost done. Any ideas would be great. There are no holes to do the grease trick
  2. #2 Re: m90 rebuild
    Wichita, KS
    Quote Originally Posted by 91z View Post
    So is it possible to do the pressure trick at all on the 04 plus?
    You could drill some holes yourself, but you would be drilling bind not knowing exactly where you are going, or what your going to go through. Not worth it.
    That's what I was saying, no holes, the bearings have to come out the same way they are pressed in. Might try your hook and slide hammer trick to remove them. Just don't mess up the case around the bearings, its soft aluminum and will dent easy so be careful.
    GenV case needle bearings are not the same size as GenIII case needle bearings so ya know. They look the same, but GenV's are a little bigger/longer. So when you order new ones, make sure you say they are for a GenV so you get the right ones. I believe the GenV's share the same sized bearing as the M112's, but don't quote me on that.
    ~F~
  1. Another Rebuild
    By bbptech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-27-2010, 04:11 AM
  2. Rebuild it?
    By Marks97GTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-17-2010, 07:22 AM
  3. rebuild $$
    By go8earn in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2010, 09:02 PM
  4. rebuild $$
    Last Post: 02-07-2010, 08:59 PM
  5. to rebuild or not to rebuild
    By indyal in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-30-2009, 04:14 PM
