Thread: Clunking....anyone???
Results 1 to 7 of 7
  1. #1 Clunking....anyone???
    GTX Level Member nikkigpgt00's Avatar
    MI
    Is anyone familiar with a clunking noise that happens when you turn or hit bumps? I have noticed this in the front left of my car. I have the Wynn's warranty and I'm trying to see what this might be so I can see if its covered????
  2. #2 Re: Clunking....anyone???
    Outer Space
    CV axles will do it on tight turns.
    02 GTP 13.6 @ 100mph - SOLD
  3. #3 Re: Clunking....anyone???
    GT Level Member Lvgrandprix2003's Avatar
    Cincinnati
    sway bar links
  4. #4 Re: Clunking....anyone???
    GTX Level Member noreasonwhyy's Avatar
    Michigan
    any of the first two or control arm bushings/ball joint
  5. #5 Re: Clunking....anyone???
    Mn
    Just sold my 2000 gt and had the same problem. I replaced all kinds of parts that i thought could have done it. Even took it to a tire shop twice! On the second time we got out the little scope and looked at the rear cradle mounts. It turned out that the bolts were tight, but the bushing was worn out and slide back and forth just enough to make a clunk when turning, going up a drive way, and under accleration. Just my 2 cents from what Ive delt with. Hope ya find it!
  6. #6 Re: Clunking....anyone???
    MI
    Ive noticed that the front end seems to a little especially at faster speeds. Does this answer more of what it could be?
  7. #7 Re: Clunking....anyone???
    Mn
    mine would only pop on initial acceleration. it wouldnt do anything more at speed or once it had a load on it.
  1. Clunking noise over bumps
    By Amb4 in forum Brakes/Suspension/Chassis
    Last Post: 08-04-2010, 08:26 PM
  2. Suspension clunking....please help
    By watters32 in forum Brakes/Suspension/Chassis
    Last Post: 04-28-2010, 10:23 AM
  3. clunking noise?
    By bensett004 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-07-2009, 02:55 AM
  4. clunking
    Last Post: 07-20-2009, 06:25 PM
  5. clunking
    By QwikGT in forum Brakes/Suspension/Chassis
    Last Post: 03-06-2009, 08:30 PM
