Thread: How bad is regular gas for your gtp?
Results 1 to 12 of 12
  1. #1 How bad is regular gas for your gtp?
    MA
    The ****in ass hole at the gas station put in regular instead of premium and I was wondering if it will do damage to my car. Also I feel like my car has lost some power because there is regular in there can that happen?
  2. #2 Re: How bad is regular gas for your gtp?
    its not very godd gas for it, but it can run on it for a liitle bit, just stay out of WOT, just wait tilll you get to 3/4 tank and fill the 1/4 will 93 and that will help make the octane level rise, then wait till 3/4 tank again and refill with 93 til full, then after that you should be good to go.
  3. #3 Re: How bad is regular gas for your gtp?
    Apr 2009
    stockton ca
    dont beat on it and you should be ok
  4. #4 Re: How bad is regular gas for your gtp?
    GT Level Member mezzoni's Avatar
    Nov 2009
    Milford, CT
    if your really concerned just get stp octane booster its 3 dollars for 3 bottles i think? either way it wouldnt hurt and you dont gotta worry about octane levels
    2006 pontiac G6 GT coupe - the daily
    2001 pontiac trans am WS6 - pacesetter headers, slp exhaust, diablo sport tuner, ported throttle body, ported MAF, SLP intake lid, B&M shifter, UMI panhard bar, lowered on koni's
  5. #5 Re: How bad is regular gas for your gtp?
    Pennsylvania
    Quote Originally Posted by mezzoni View Post
    Read: http://www.grandprixforums.net/what-...here-1507.html
  6. #6 Re: How bad is regular gas for your gtp?
    GTP Level Member SnowDrift's Avatar
    Apr 2009
    Central Ohio map dot.
    and just for future reference, never let anyone pump your gas.
  7. #7 Re: How bad is regular gas for your gtp?
    In some states it's not an option about who pumps the fuel. Take a close look at octane boosters, most raise the octane only a point which is say from 87 to 87.1
    When you say they put in regular, what octane is your regular? In crossing the country I found that some places call 85 regular. To me that's some sad dinosaur piss. Then there's other parts of the country that have 91 octane as their premium w/o anything higher available.
    Yes, I like the northeast where 93 is standard premium and 94 is available at Sunoco
  8. #8 Re: How bad is regular gas for your gtp?
    Apr 2009
    Yeah, I know. Kind of a peave of mine, I guess. I'd have a real problem with that, if I accidentally found myself needing fuel in one of those states.
  9. #9 Re: How bad is regular gas for your gtp?
    MA
    Does the car's power drop when useing regular
  10. #10 Re: How bad is regular gas for your gtp?
    yeah, and it could cause the engine to ping a little, but your should be fine, the fuel octane is just not high enough for the engine to run at its best.
  11. #11 Re: How bad is regular gas for your gtp?
    GT Level Member AmericanRiceEater's Avatar
    New York
    i ran my car on 87 for about 6 months before i started modding it lol. all i use now a days is 93 though
    Black 2000 GTP Coupe. SSAutoChrome headers, K&N Cold Air Intake, Reptile Tuned PCM, 3.4" ZZP MPS, 104 Autolites & 180 Stat.
    PS3 Online: Zirpola (Dont use mic.)
  12. #12 Re: How bad is regular gas for your gtp?
    As long as your not going WOT it'll be fine...just run it down...stay out of the gas...and fill 'er up with higher octane when you would normally fill up.
    I will say go kick the guy in the throat that pumped it.
  1. oil: synthetic or regular??
    By WHITEGPGT06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2010, 06:46 AM
  2. Replace Magnasteer Rack with Regular Rack?
    By Smoker324 in forum General Tech Discussion
    Last Post: 06-29-2010, 09:11 PM
  3. Sythetic VS Regular 5W30
    By Fubisin in forum General Tech Discussion
    Last Post: 10-21-2009, 10:00 PM
  4. Replies: 3
    Last Post: 10-21-2009, 10:18 AM
