Thread: Tuning question
Results 1 to 8 of 8
  1. #1 Tuning question
    SE Level Member xsvtank's Avatar
    NJ
    ok guys heres my question im getting my car tuned by a friend (worked for SLP) and hes going to tune my GTP
    Whats the safest and most efficient shift point to set the car to (RPM)
    and with a custom tune and my car (Headers, 2 range colder plugs, CAI, 180* t-stat) what should be the right pulley to put on. i have a 3.4 but with a custom tune should i o can i go lower?
    Also im new to this what else do custom PCM's do that i should have him do to mine.
    Thank you,
    Frank
  2. #2 Re: Tuning question
    Charles City, IA
    shift at 5800-6k, unless you run a big cam then you can go a little higher. 3.4 will probably be what you want, no one can tell you for sure.
    SMGPFC Two Nipple General
  3. #3 Re: Tuning question
    NJ
    okay ill prolly jus have it at 6 grand and im debating to get a 3.25 or stay with the 3.4 for now my goal is mid 13's and wanna trap 100+
  4. #4 Re: Tuning question
    Charles City, IA
    A smaller pulley will not make you faster, if you can not flow it.
  5. #5 Re: Tuning question
    NJ
    true but i want to see how much i can flow with headers and no cam or rockers
  6. #6 Re: Tuning question
    GTX Level Member Rather B Blown's Avatar
    Dec 2008
    London, Ontario
    not enough for a 3.25 pulley
    Quote Originally Posted by Reptile
    It sounds like you accidentally stuffed a midget in the downpipe, and he's hammering out an SOS to get out.
  7. #7 Re: Tuning question
    you might be able to pull it off. some cars take less than others. the only way to know is to try.
  8. #8 Re: Tuning question
    Dec 2008
    London, Ontario
    scan first and see if you have kr on a 3.4
  1. tuning
    By nicksilvergt99 in forum General Tech Discussion
    Last Post: 08-30-2009, 05:40 PM
  2. bad tuning and no way of getting better
    By fst in forum PCM Tuning
    Last Post: 08-27-2008, 02:03 PM
  3. Powertuner fuel tuning question......
    By Iron Indian in forum PCM Tuning
    Last Post: 08-23-2008, 09:29 PM
  4. Quick question about tuning
    By Freebeer187 in forum General Tech Discussion
    Last Post: 08-21-2008, 09:49 AM
