Thread: What Else Will Go Wrong?
Results 1 to 11 of 11
GrandPrixChic02 What Else Will Go Wrong? 07-22-2010, 09:52 PM
SlowNA06 Re: What Else Will Go Wrong? 07-22-2010, 11:23 PM
Rather B Blown Re: What Else Will Go Wrong? 07-23-2010, 11:28 AM
Jakegday Re: What Else Will Go Wrong? 07-23-2010, 12:17 PM
Pepino Re: What Else Will Go Wrong? 07-23-2010, 12:40 PM
GrandPrixChic02 Re: What Else Will Go Wrong? 07-23-2010, 09:04 PM
matt5112 Re: What Else Will Go Wrong? 07-24-2010, 09:32 AM
noreasonwhyy Re: What Else Will Go Wrong? 07-23-2010, 12:16 PM
blueguy Re: What Else Will Go Wrong? 07-23-2010, 11:57 PM
Rather B Blown Re: What Else Will Go Wrong? 07-24-2010, 12:35 AM
blueguy Re: What Else Will Go Wrong? 07-24-2010, 04:00 AM
  1. #1 What Else Will Go Wrong?
    Jul 2010
    IA
    I had my 02 GT in the shop today because I fell victim to the blower working only on speed 5 and the headlights not coming on. That was the ignition wiring problem and cost me $530. Then I am told that my front sway bar has a crack on both ends and my plentum gasket is leaking coolant and will be $750 to fix gasket and $330 to fix sway bar. I also have that lovely issue of rain on the passenger floorboard and while I was at the shop I ordered the deflector.
    I have had a pretty much trouble free 8 years with this car. I don't know if I should just fix all and hope it all is well. Are there any other things that are common issues with Grand Prixs that I should look forward to?
  2. #2 Re: What Else Will Go Wrong?
    Pennsylvania
    Aside from catching fire, they don't seem to have a whole lot of problems across the board, with the exception of poorly made rear trailing arms.
  3. #3 Re: What Else Will Go Wrong?
    GTX Level Member Rather B Blown's Avatar
    Dec 2008
    London, Ontario
    330 seems a bit high to do a sway bar and 750 to do an intake plenum gasket is unreal. Shop around for better prices
    Quote Originally Posted by Reptile
    It sounds like you accidentally stuffed a midget in the downpipe, and he's hammering out an SOS to get out.
  4. #4 Re: What Else Will Go Wrong?
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    Quote Originally Posted by Rather B Blown View Post
    x2 on ALL of that. my upper intake plenum costed me $300 at a shop. and a sway bar is easier then piss to replace
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  5. #5 Re: What Else Will Go Wrong?
    Brewcity, WI
    the upper intake plenum is also easier then piss..... and if you've never had the LIM gaskets replaced... your going to need to. Just did mine at 123K miles, also an '02.
    Self-denied SMGPFC member #1
    SEARCH works!
  6. #6 Re: What Else Will Go Wrong?
    Jul 2010
    IA
    Thanks all, for the opinions. Husband feels he can take care of the sway bar. This was the Pontiac garage quoting me the prices. Thought I should take it to a GM dealer. I am going to see about getting a second opinion. Love her too much to let her go just yet!
  7. #7 Re: What Else Will Go Wrong?
    Quote Originally Posted by Pepino View Post
    mine had 80 K on 'em and they were shot.
  8. #8 Re: What Else Will Go Wrong?
    GTX Level Member noreasonwhyy's Avatar
    Michigan
    those are some high quotes for those jobs.
    my suggestion is to find someone local who could assist you with your car troubles. you could save yourself loads of money and give someone local[hopefully from GPF] some extra cash.
  9. #9 Re: What Else Will Go Wrong?
    If he can do the sway bar...then he can do the UIM/LIM gaskets...I'd rather do top end **** then mess with the sway bar anyday IMO.
  10. #10 Re: What Else Will Go Wrong?
    Dec 2008
    London, Ontario
    same..and sway bars are cake, just unbolt your links and the rubber bushings in the middle of the bar. UIM is even easier..very straight forward
  11. #11 Re: What Else Will Go Wrong?
    I just hate anything suspension related...I'm a skinny f*ck. That sh1t requires air tools or lots of muscle...neither of which I have LOL
  1. WTF is wrong now? 99 GTP
    By LSXHP in forum Audio, Security & Visual Electronics
    Last Post: 03-12-2010, 12:42 PM
  2. What am I doing wrong??
    By silverstreak in forum Off Topic Discussion
    Last Post: 09-11-2009, 08:59 AM
  3. need some help, something is seriously wrong
    By red60degreeGP in forum General Tech Discussion
    Last Post: 07-08-2009, 09:16 AM
  4. Something's Very Wrong
    By BwolfGT in forum Track Sessions and Kills
    Last Post: 04-24-2009, 10:04 PM
  5. WTF am i doing wrong
    By 04 GTP COMP G in forum Forum Bugs/Suggestions
    Last Post: 12-29-2008, 05:43 PM
