Thread: Open cone question
Results 1 to 8 of 8
  1. #1 Re: Open cone question
    Outer Space
    Probably because when you mess with intakes.. it changes how the MAF sensor reads (hz). Therefore, a quick run around the block... would not be a good test. Disconnect battery for like 15 minutes (to reset LTFT's) and then run it for an extended period of time. This will allow the PCM to learn its fuel trims which in turn works with the MAF.
    Temperature does affect it... however... I dont think it the reason you feel that.
    02 GTP 13.6 @ 100mph - SOLD
  2. #2 Re: Open cone question
    Pennsylvania
    Maybe it's a perspective thing, but that doesn't seem to be so much a cone as a... cylinder.
  3. #3 Re: Open cone question
    Donating Users zildjian102's Avatar
    Wilkes Barre, PA
    Lol the filter?
    2002 Grand Prix GT- top swap soon
    1997 Pontiac Grand Prix GTP-project/parts
    3.4 pulley, intense tune, SD headers, intake, 180 tstat, al104's
  4. #4 Re: Open cone question
    SE Level Member ParanoidVengeance's Avatar
    Jun 2010
    Canton
    Heat will be a issue. The air needs to come in from a outside source. Not air being heated up by the exhaust crossover pipe right under it.
    Even making a box to go around it were it sits would probly help.
    Cold air intakes are the best. This is a hot air intake.lol
    2004 Monte Carlo Supercharged transplant
    Comp Cams 1.9 rockers
    Headers w/3 inch exhaust no cat
    Gutted Air Box,ZZP 1.0 PCM Dyno Tuned
  5. #5 Re: Open cone question
    Quote Originally Posted by ParanoidVengeance View Post
    Wrong jeeves. Already dyno proven by the 06NA guy in here. Open Cone is FTW...it is all about flow in these cars...to hell with cold temps...it dont matter for ****. Put it in there like so.
  6. #6 Re: Open cone question
    Pennsylvania
    After looking at the photo again, I have this to say: you may want to move your coolant bottle (replace will... 99+ I think) - that's the reason this setup looks funky. Once that's gone, the setup will make much more sense.
    What you have now is better than stock. To improve upon your design, move the coolant bottle, buy a 9" cone intake, and point it kinda at your headlight (22.5* bend). OR slap it right on the throttle body (still move the coolant bottle - air comes in from behind the headlight).
    Actually, that's the throttle body right on top of the crossover pipe. The air's going to be heated up here no matter what.
    Here's a link to some empirical evidence.
  1. open cone
    By CompCam21 in forum General Tech Discussion
    Last Post: 06-05-2010, 09:39 PM
  2. Another open cone vs sealed box debate
    By cleangtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-25-2010, 05:01 PM
  3. open cone filter
    By GTP Ryan in forum Off Topic Discussion
    Last Post: 04-20-2010, 10:47 PM
  4. open cone filters
    By TorqueAutoMotiv in forum Off Topic Discussion
    Last Post: 11-16-2009, 07:30 PM
  5. Open Cone Performance.
    By PontiacGTPSE in forum Off Topic Discussion
    Last Post: 10-21-2009, 11:03 AM
