Thread: Tune up?
Results 1 to 16 of 16
  1. #1 Tune up?
    NE Philly
    Hey guys, Got some free time so I think its tune up time for my 03 GT. She has about 80,000 miles on her. I replaced the fuel filter today so that’s done with and besides spark plugs what else should I replace? Also how should I go about changing the transmission fluid? Last thing, I’m thinking about putting some fuel injector cleaner in her as well. Good idea? If so what brad you guys like?
  2. #2 Re: Tune up?
    Charles City, IA
    Check your air filter
    Plug wires, you will probally break the old ones when you take them off
    I use sea foam in the gas tank.
    Best way to change the transmission fluid is take it to a shop and have them flush it with a machine. Gets all the old out while putting in new. I would not worry about the trans filter, unless Your old fluid is really burnt and you are having transmission problems.
    SMGPFC Two Nipple General
  3. #3 Re: Tune up?
    NE Philly
    Fluid is still pink with little to no burnt smell. Just wanna keep it that way! What about a pvc vavle or something like that?
  4. #4 Re: Tune up?
    Charles City, IA
    You can switch that out too if you want. It is under your map sensor on the left side of the plenum as you are looking at it from the front.
  5. #5 Re: Tune up?
    Donating Users Rust's Avatar
    Jun 2010
    Canada
    Change the cabin air filter if you have it. You wont believe the crap built up in that. PCV valve is easy. Flush and replace Dex cool. Sea foam the engine through the vacuum lines. pull out the throttle body screen and spray the butterfly valve with throttle body/carb cleaner, clean out the sticky junk.
    New thermostat. Air filter. Plugs. Wires. Replacing any fluid is good.
    You've done the fuel filter already. Might as well change the oil seeing as you are doing everything else.
    All pretty cheap, easy fun to do stuff.
    I like Lucas upper cylinder lubricant/injector cleaner myself. Or Sea foam.
  6. #6 Re: Tune up?
    NE Philly
    Just poked around, I have the 2 part cowl but no air filter under it. Whats the part number for one?
    PS" also anyone got a pic of how the windshield washer lines should be run, i feel like i got mine int he wrong place.
    Thanks!
  7. #7 Re: Tune up?
    Jun 2010
    Canada
    Fram part # for Monte's and Impala's is CF8392 or CF8392A if you want the fancier one. fram.com will show you all of the competitors part #'s if you prefer another maker.
    It did not show a cabin air filter for an 03 GP though. Strange. Does yours have one?
    Here is a link for an 04 GP cabin filter install with pics, just to compare.
    Sparky's Answers: 2004 Pontiac Grand Prix, Changing The Cabin Air Filter
  8. #8 Re: Tune up?
    NE Philly
    non there but it looks like there a spot for one. Ill pick one up for a monte carlo from wally world and see if it fits
  9. #9 Re: Tune up?
    The ones from the Regal fit if the Imp/Monte one doesn't.
  10. #10 Re: Tune up?
    Brewcity, WI
    Quote Originally Posted by Rust View Post
    I believe 97-03 grand prixs were the only wbody without this filter.....
    Self-denied SMGPFC member #1
    SEARCH works!
  11. #11 Re: Tune up?
    GTP Level Member
    springfield IL
    i am bout to fix my water/blower moduale problem 2nite.... got the water deflector from GM and stopped in autozone to pick up a cabin filter..
    guy looked on computer and said there is one made for... told just give me one that will fit a regal.. he still says it wont fit.. i said i read about it on the forums, he replys.. dont beleive everything you read or hear!!
    he still swears it wont fit.. said he would see me 2marow to get my money back!! might leave my cowl off just to show him wrong!!! HEHEHEHEHEH
  12. #12 Re: Tune up?
    GTX Level Member 03GTPLE's Avatar
    Tyler, TX
    Quote Originally Posted by tc300 View Post
    you should do it
    2003 White Grand Prix GTP Limited Edition
    - 3.4 pulley, tune by Boostd1/CLINT@AIR, Short Ram Intake, PLOG, 3" ZZP Downpipe, AL 104's, 180* t-stat, Impala STB & 12" cross drilled/slotted/zinc washed rotors, DDM HID's, and put in a heads up display for now...
  13. #13 Re: Tune up?
    Charles City, IA
    most people that work at autozones are complete retards.
  14. #14 Re: Tune up?
    GTP Level Member
    springfield IL
    U P D A T E........
    so 2day after i got my drain defelctor and a "buick" cabin filter in, i decided to leave a few screws out of the cowl and took a drive back to the autozone... same guy as yesterday was there.. he was like "soo your back for refund huh..??!! i said no i would like to show you something.. LOL
    came outside took the screw out and pulled of the cowl to show him the "buick" cabin filter... can you guess what the guy said...?????
    told me i was dumb for doin this, it was goin to make any difference cause GPs dont come with one from factory.. i kinda let it go, didnt say anything back to but i had a D A M N GOOD LAUGH!! got back inside to buy some parts(2 timken wheel bearings, axel shaft and a tie rod joint) dude was being a smartazz now.. "would you like these parts to fit a buick too?!?!?"
    i said "im sure some will fit being made by GM... fyi GM does make cars where the same parts fit diff models ya know.. doesnt your computer show you this??" the started a pretty heated arguement in front of ppl at the store.. we were calling each other every name in the book!! LOL a coworker took him back into the stock area. another worker told me to get my F'n A s s outa there.. as i was leaving i gave a speach to the customers in the store that were standing there with in shock and aw.. "see how great autozone is!! these ppl dont know anything about cars! im goin to o'rileys to get my parts were the service is FRIENDLY!" as i walked out 4ppl followed.. when i got to o'rileys i seen 3 of the ppl there from autozone!!! job well done!! L M F A O
    sorry bout the long rant but it was good!!
  15. #15 Re: Tune up?
    Tyler, TX
    wow.... too bad you missed out on your autozone credits...
    that guy is a retard.
  16. #16 Re: Tune up?
    Pennsylvania
    As far as preventative maintenance: Dealership tranny flush (they use SOP, which is to not use any detergents, unlike some other shops might), coolant flush, oil change, new spark plugs, new spark plug wires, cabin air filter, intake filter, clean MAF, clean throttle body, fuel filter, GM fuel treatment.
  1. need a tune in az!!
    By Joe m in forum Southwest
    Last Post: 11-03-2010, 11:27 AM
  2. How to get a tune
    By 06grandprix93 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-24-2010, 09:01 PM
  3. Tune up
    By JB381 in forum Engine
    Last Post: 02-22-2010, 06:34 PM
  4. Tune-up help
    By busagtp in forum General Tech Discussion
    Last Post: 09-09-2009, 01:32 AM
  5. First tune up!
    By crywolf in forum General Tech Discussion
    Last Post: 12-18-2008, 01:12 AM
