Thread: HID light install
Results 1 to 13 of 13
  1. #1 HID light install
    Jul 2010
    Moncton
    Does anyone have a guide to install HID lights on a 2005 grand prix it would help me alot and be much apreciated thx.
  2. #2 Re: HID light install
    May 2008
    staten island,NY
    this comes up at least once a day, use the search button type in HID and click appearance and it will take you to the HID threads. they are plug and play, make sure you pick up a relay harness too, i bought mine from VVME.com
  3. #3 Re: HID light install
    Donating Users Ibwrong's Avatar
    Oklahoma City
    ^^ This.. Its as simple as replacing your bulbs.. Then find a place to mount the balast...
    2000 GTP - Project
    2000 Mustang GT
    2006 Charger
  4. #4 Re: HID light install
    GTX Level Member tayl5645's Avatar
    Jul 2010
    Michigan
    Ok so i see alot of people say to pick p a harness and others say that its plg and play. Why is there a difference in opinion?
  5. #5 Re: HID light install
    Pennsylvania
    Harness is $10 to make sure you don't break your car.
  6. #6 Re: HID light install
    Jul 2010
    Moncton
    Alright but I got my lights with everything with it but in the instructions at some point it says I have to drill a 25 mm hole somewhere has anyone incountered this before?
  7. #7 Re: HID light install
    The LED guy.... csssaint12's Avatar
    Nov 2009
    Duluth, Minnesota, United States
    it says to do it but from what i see is that the only reason for the hole is for a barrier the prevents you from wiring it. When i installed my headlights i didnt do it because there is no need for it. if you want i can take pictures of mine and send them to you. im sure the 08's and 05 headlights are the same
  8. #8 Re: HID light install
    Jul 2010
    Moncton
    Sure man that would be great my email is heresthebearintheair@hotmail.com this is much apreciated and one thing I was told that these headlights are illegal true or not? And will the 8000k lights be to bright as low beams?
  9. #9 Re: HID light install
    Charles City, IA
    8000k have less light out put then 6000k.
    SMGPFC Two Nipple General
  10. #10 Re: HID light install
    Jul 2010
    Moncton
    So the 12000k ones aren't necessarily the brightest ones?
  11. #11 Re: HID light install
    Nov 2009
    the lower the color (based on the Kelvin temp for example 6000k do now put as much lights as 3000k ones). I have not heard that they are illegal but that could be a state law or county law. It also depends on the type of ballast you get with your HID kit
  12. #12 Re: HID light install
    Jul 2010
    Michigan
    Can you jst post the pics of what you have done on here as it will be helpful for other 05 drivers who may be looking at this thread
  13. #13 Re: HID light install
    GTP Level Member Scimmia's Avatar
    QCA, IA
    Quote Originally Posted by BennyG View Post
    True. Headlights are DOT approved as a unit, and any modification of that unit, including using a different bulb type, makes them non-approved, and therefor illegal on the road.
    2001 Buick Regal LS - Almost Stock
  1. Water in LR brake light housing/ABS light
    By andante147 in forum General Tech Discussion
    Last Post: 05-31-2010, 08:01 PM
  2. Replies: 16
    Last Post: 01-23-2010, 09:43 AM
  3. Airbag cluster light? ABS/Trac light too?
    By oddwraith in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-15-2009, 09:57 AM
  4. ABS Light + Check Tire Press. Light Problems
    By element55 in forum Brakes/Suspension/Chassis
    Last Post: 01-30-2009, 02:34 PM
  5. 4th Brake Light install, thanks DrunkNMonkey!!
    By GeddyLee in forum Visual/Body Modifications
    Last Post: 08-11-2008, 09:55 AM
