Thread: stalls when raining
Results 1 to 9 of 9
  1. #1 stalls when raining
    GTX Level Member EJOUIE's Avatar
    Newnan, GA
    On my way home from work my GP stalled out while moving. Sat for 20 minutes or so in the road as it locked up and the steering wouldn't turn to be moved to the side. Then it fired up and ran fine. I tried starting it a few times during the 20 min span, but did not come close to running it. I think it may have something to do with the heavy rain that I drove through getting something wet. Deepest puddle was only an inch deep though. Any ideas on what could cause this and how to prevent it from happening again?
    97 GT white 4 door-SOLD
    Cherry 2005 Impala LS- Front and Rear GMPP Strut Tower Braces
  2. #2 Re: stalls when raining
    MA
    check your plug wires
    SMGPFC Member #9
  3. #3 Re: stalls when raining
    GT Level Member GrandPrixSE's Avatar
    Jun 2010
    Indy
    Quote Originally Posted by SilvaMan61 View Post
    Yes, good area to start. I have hit some deep puddles myself, and after I let her sit for a few, started just fine, and once they are dry, runs like it never happened.
    2000 Buick LeSabre Custom - 3800 Series II V6
    1998 Buick LeSabre Custom - 3800 Series II V6 ​SOLD!
  4. #4 Re: stalls when raining
    SexyStudmuffin copperpacecar's Avatar
    Feb 2010
    somewhere cold
    pop your hood at night and with no lights on rev your motor...if u see little flashes of light goto a parts store and buy some dialectric for the wires...comes in little packets...put that in your plug boots on both ends and see if that solves it.
  5. #5 Re: stalls when raining
    Newnan, GA
    Quote Originally Posted by copperpacecar View Post
    Do you mean with no hood light, as i cant shut off the headlights at night.
    So it seems that the wiring around the plugs is what is the consensus for the source of the problem. Makes sense because I bet the previous owner did not replace any of that wiring and she stored in a barn during the winter. At one point mice were living in it.
  6. #6 Re: stalls when raining
    Feb 2010
    somewhere cold
    even if u get new wires though make sure u get the goop to put in the boots as new ones will do it too
  7. #7 Re: stalls when raining
    I'd pop off the wheel and splash shield on the passenger side. Take a good look at that crank sensor connector. That's the lowest sensor that can cause a stall like you describe. Plug wires/ICM are a bit high on the motor and usually don't get very wet in the rain or a splash from a puddle. Although they can be at fault. Just sayin...it's more likely a crank sensor.
  8. #8 Re: stalls when raining
    Brewcity, WI
    Quote Originally Posted by EJOUIE View Post
    engage your emergency brake before starting your car....
    Self-denied SMGPFC member #1
    SEARCH works!
  9. #9 Re: stalls when raining
    Newnan, GA
    Quote Originally Posted by Pepino View Post
    Oh. I rarely need to use the E brake so I forgot it did that.
  1. 00 GT Starts then stalls?
    By dynamicyaz in forum Introductions/Noob Questions
    Last Post: 04-13-2010, 03:08 PM
  2. Car Starts and Stalls
    By 1000PRIX in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-05-2010, 09:40 PM
  3. Stalls under load.
    By reem82 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-06-2009, 11:52 PM
  4. Stalls in Morning only.
    By SuperSport in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-27-2009, 11:25 AM
  5. Car Stalls PLEASE HELP!!!
    By GRANDPRIXFOOL01 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-04-2009, 05:26 PM
