Does anybody know if the washer fluid pump on a 03 has a fuse? or if it stopped spraying then the pump is bad? Mine stopped spraying and doesn't even make noise anymore when I try to spray it.
I believe there is a fuse. I replaced the pump on mine a while back. It was like $12 and pretty simple to replace.
ok cool sounds easy to do and cheap. I looked in the manual for a fuse and did not see one for the pump. Couldn't be on the same fuse as the wipers themselves because they still work. I will look again
i couldnt find a fuse, so i replaced the motor..its a pretty cheap part and not hard to replace...g luck tho
The easiest way to replace the pump is to turn the wheels all the way to the right and pull off a few of the screws that hold the inner fender on. Then I think the pump will just pull out of the tank.
ok thanks, i will just replace it for 15 bucks and see if that's the problem. Sounds easy to do.
Changed the pump today for $16 at autozone and works again. I don't think there is a fuse for this and could not find one listed in the diagram. Could be wrong but just seems like the pump goes bad. Just wanted to update.
on a 97 gtp is the washer fluid pump on the outside of resvoir because there is a little black cyclinder on the side not sure if thats just like a vacum hose or something
so does that sound like thats the issue with no fluid coming out? would this be a junkyard part or new part
