Thread: getting annoyed...
Results 1 to 9 of 9
  1. #1 Re: getting annoyed...
    Joliet, IL
    Quote Originally Posted by 99prixgt View Post
    my car always hits 210 before the t-stat opens, then it never gets above 180*. As far as bleeding the system, any coolant coming out you should be good and bled.
    kind of off topic but, did you ship out my shifter yet?
    went out today sorry for the delay.....its been shyt storm for me lately....
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  2. #2 Re: getting annoyed...
    Jan 1970
    Maquoketa, Iowa
    Did you open up the coolant passage below the tb on the lim about 1/8-1/4" when blocking the coolant passage at the tb?
  3. #3 Re: getting annoyed...
    Joliet, IL
    Quote Originally Posted by FoSHO99 View Post
    no....do i grind down the block plate of the wall inside the LIM?
    00 Silvermist GTP
  4. #4 Re: getting annoyed...
    Yup..under the TB on the LIM is a little plate with 2 8mm bolts holding it on. Pull that and open up the passages a bit. that's coolant flow from rear to front heads.
  1. Annoyed...
    By wmshoemaker in forum The Rant Forum
    Last Post: 11-13-2009, 09:52 AM
