Thread: getting annoyed...
Results 1 to 9 of 9
  1. #1 Re: getting annoyed...
    Jersey
    my car always hits 210 before the t-stat opens, then it never gets above 180*. As far as bleeding the system, any coolant coming out you should be good and bled.
    kind of off topic but, did you ship out my shifter yet?
    16' wrx sti- stock
  2. #2 Re: getting annoyed...
    Joliet, IL
    Quote Originally Posted by 99prixgt View Post
    went out today sorry for the delay.....its been shyt storm for me lately....
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  3. #3 Re: getting annoyed...
    Jan 1970
    Maquoketa, Iowa
    Did you open up the coolant passage below the tb on the lim about 1/8-1/4" when blocking the coolant passage at the tb?
  4. #4 Re: getting annoyed...
    Joliet, IL
    Quote Originally Posted by FoSHO99 View Post
    no....do i grind down the block plate of the wall inside the LIM?
    00 Silvermist GTP
  5. #5 Re: getting annoyed...
    Yup..under the TB on the LIM is a little plate with 2 8mm bolts holding it on. Pull that and open up the passages a bit. that's coolant flow from rear to front heads.
  1. Annoyed...
    By wmshoemaker in forum The Rant Forum
    Last Post: 11-13-2009, 09:52 AM
