Thread: poor MPG after tune up
Results 1 to 20 of 22
  1. #1 poor MPG after tune up
    SE Level Member christopher8911's Avatar
    North Carolina
    Having some issues with my 98 GT. After installing new LIM (GM aluminum replacements) gaskets, new Shure fix UIM and gasket, new heat senser, new 180 t-stat, new tps senser, new SLP intake, new pvc valve, and replaced vaccume line from throttle body to the intake (EGR maybe?)my gas MPG is around 12. The car seems to be running good and I don't know what is killing my gas mileage. Car does idle around 900 rpm, seems a little higher than normal. Before the swap I was getting around 20 mpg in town. I have checked for v leaks and everything seems to be tight. What should I do next?
  2. #2 Re: poor MPG after tune up
    Charles City, IA
    Check the spark plugs. Check your fuel pressure regulator.
    SMGPFC Two Nipple General
  3. #3 Re: poor MPG after tune up
    North Carolina
    I did clean the tb and the fuel rails, changed the o rings on the injectors. Maybe I took it out of adjustment when I removed it from the car.
  4. #4 Re: poor MPG after tune up
    North Carolina
    How do I check the fuel pressure regulator?
  5. #5 Re: poor MPG after tune up
    GTX Level Member Biohazed's Avatar
    Philadelphia, Pennsylvania, United States
    would be interested seeing this resolved, MY GT does the same; crappy gas mileage and also idles at 900, I really haven't had the time to get to the bottom of what is wrong.
    *image too tall*
    BMR F + R Strut Bars - Falken Torque V 18's - JVC S900 - Kicker C10's - Spyder Projectors, Wizaird,
  6. #6 Re: poor MPG after tune up
    Charles City, IA
    Quote Originally Posted by christopher8911 View Post
    Was there some gas in the vacuum line connected to it? Do you have a vacuum pump? If you do put about 25" of vacuum to it and see if gas leaks out.
  7. #7 Re: poor MPG after tune up
    North Carolina
    I can't remember. The vaccume side is the bank closest to the radiator, right? Do you think it could bt the tps? I cleaned the tb to an almost polished state and replaced the tps while I was at it. Car ran great before the upgrades, only had a lim leak that needed fixing. Feel like its something to do with my updates. Also, no rich exhaust smell or smoke coming from exhaust.
  8. #8 Re: poor MPG after tune up
    GTP Level Member SuperSport's Avatar
    Michigan
    and replaced the tps while I was at it..
    The TPS is spring loaded and installs with the lip under the tab. So you gotta twist it under that, then twist the body of the TPS to line up with the screw holes.
    If you just dropped the TPS in, its installed wrong.
    Also, a new SLP intake...more air means more gas, but im not sure that it would warrant only 12mpgs...
    2001 Grand Prix GT Coupe
    Comp G Wheels - SS Corners - Infinity Sound - Tint - Digital DIC Swap - 893 Fogs
  9. #9 Re: poor MPG after tune up
    North Carolina
    Ill re-check the tps first and try that since it will be the easiest to fix. I feel like its a fuel issue more than a vaccum problem. Ill change the spark plugs and wires while I'm under the hood. Thanks guys I haven't had much experience with the 3.8, I'm a V8 kind of guy
  10. #10 Re: poor MPG after tune up
    North Carolina
    OK I removed the tps and pushed it in as far as it would go, then rotated the body to line up with the screw holes. Still no luck
  11. #11 Re: poor MPG after tune up
    GTP Level Member Smokin2000gtp's Avatar
    Jul 2008
    Dekalb, IL
    How old is your O2sensor? Oh and you said you just put on a SLP intake, did you oil the filter yourself? Maybe try cleaning your MAF.
    2000 Silvermist Grand Prix GTP Coupe
    Mods-Custom Thrasher CAI|Ceramic Coated S&S Headers|3.4" pulley|ZZP S4 Blower|Powrtuner|PRJ 10.4mm wires|HIDs|F-Body brakes|Koni's and Voglant's|
  12. #12 Re: poor MPG after tune up
    North Carolina
    not shure about the o2 sensor but thats my next corse of action. getting frusterated with this car.
  13. #13 Re: poor MPG after tune up
    North Carolina
    Changed o2 sensor, still no luck. Going to change the plugs and wires, what heat range should I get? Car is stock except for the cai and I will be adding headers soon. Want to get the mpg issue fixed before I get too far on mods.
  14. #14 Re: poor MPG after tune up
    Pennsylvania
    Stock heat range.
  15. #15 Re: poor MPG after tune up
    North Carolina
    Finished installing my digital dic and my mpg in town is 13.4, open road is 18.8. How far off is that from normal for a pretty much stock car?
  16. #16 Re: poor MPG after tune up
    i get 18-19 city, which really only the 3 mile drive to work and the 3 miles back home. On the open road like a county road or the freeway I can get 28-32 depending on speed.
  17. #17 Re: poor MPG after tune up
  18. #18 Re: poor MPG after tune up
    North Carolina
    Damn, that is what I figured. What does your n/a cars rpm show at idle without a/c? With a/c? I'm around 900 either way. Seems high to me.
  19. #19 Re: poor MPG after tune up
    i know your asking for N/A, but i think the idle for n/a and s/c should be about the same.
    my gtp rpms at idle are:
    without a/c: 700-750
    with a/c: 800
  20. #20 Re: poor MPG after tune up
    North Carolina
    Thanks for the info. Going to get a new IAC valve tom. Maybe that will help
  1. poor gas mileage
    By 05grandprixgt in forum General Tech Discussion
    Last Post: 02-14-2010, 07:32 AM
  2. P0121 & poor performance after dyno tune
    By nugzo in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-13-2009, 04:11 PM
  3. Poor mpg! Help
    By rocafella2032 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-11-2009, 08:15 PM
  4. poor GTP
    By hotshot in forum The Rant Forum
    Last Post: 10-01-2008, 08:08 AM
  5. Piss Poor MPG
    By Toofastgs in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-28-2008, 11:42 AM
