Thread: poor MPG after tune up
Results 1 to 20 of 22
christopher8911 poor MPG after tune up 07-12-2010, 03:13 PM
TheOtherNick Re: poor MPG after tune up 07-12-2010, 05:50 PM
christopher8911 Re: poor MPG after tune up 07-12-2010, 05:59 PM
TheOtherNick Re: poor MPG after tune up 07-12-2010, 06:11 PM
christopher8911 Re: poor MPG after tune up 07-12-2010, 05:56 PM
Biohazed Re: poor MPG after tune up 07-12-2010, 06:03 PM
christopher8911 Re: poor MPG after tune up 07-12-2010, 06:35 PM
SuperSport Re: poor MPG after tune up 07-12-2010, 09:45 PM
christopher8911 Re: poor MPG after tune up 07-12-2010, 10:08 PM
christopher8911 Re: poor MPG after tune up 07-13-2010, 12:23 PM
Smokin2000gtp Re: poor MPG after tune up 07-13-2010, 01:23 PM
christopher8911 Re: poor MPG after tune up 07-13-2010, 05:12 PM
christopher8911 Re: poor MPG after tune up 07-18-2010, 12:14 PM
SlowNA06 Re: poor MPG after tune up 07-18-2010, 12:48 PM
christopher8911 Re: poor MPG after tune up 07-20-2010, 01:19 PM
Fivefingerdeathpunch Re: poor MPG after tune up 07-20-2010, 01:21 PM
Bio248 Re: poor MPG after tune up 07-20-2010, 01:22 PM
christopher8911 Re: poor MPG after tune up 07-20-2010, 01:30 PM
Fivefingerdeathpunch Re: poor MPG after tune up 07-20-2010, 02:15 PM
christopher8911 Re: poor MPG after tune up 07-21-2010, 06:26 PM
benner Re: poor MPG after tune up 07-21-2010, 07:44 PM
Smokin2000gtp Re: poor MPG after tune up 07-22-2010, 06:20 PM
  1. #1 Re: poor MPG after tune up
    SE Level Member christopher8911's Avatar
    North Carolina
    I can't remember. The vaccume side is the bank closest to the radiator, right? Do you think it could bt the tps? I cleaned the tb to an almost polished state and replaced the tps while I was at it. Car ran great before the upgrades, only had a lim leak that needed fixing. Feel like its something to do with my updates. Also, no rich exhaust smell or smoke coming from exhaust.
  2. #2 Re: poor MPG after tune up
    GTP Level Member SuperSport's Avatar
    Michigan
    Quote Originally Posted by christopher8911 View Post
    and replaced the tps while I was at it..
    The TPS is spring loaded and installs with the lip under the tab. So you gotta twist it under that, then twist the body of the TPS to line up with the screw holes.
    If you just dropped the TPS in, its installed wrong.
    Also, a new SLP intake...more air means more gas, but im not sure that it would warrant only 12mpgs...
    2001 Grand Prix GT Coupe
    Comp G Wheels - SS Corners - Infinity Sound - Tint - Digital DIC Swap - 893 Fogs
  3. #3 Re: poor MPG after tune up
    North Carolina
    Ill re-check the tps first and try that since it will be the easiest to fix. I feel like its a fuel issue more than a vaccum problem. Ill change the spark plugs and wires while I'm under the hood. Thanks guys I haven't had much experience with the 3.8, I'm a V8 kind of guy
  1. poor gas mileage
    By 05grandprixgt in forum General Tech Discussion
    Last Post: 02-14-2010, 07:32 AM
  2. P0121 & poor performance after dyno tune
    By nugzo in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-13-2009, 04:11 PM
  3. Poor mpg! Help
    By rocafella2032 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-11-2009, 08:15 PM
  4. poor GTP
    By hotshot in forum The Rant Forum
    Last Post: 10-01-2008, 08:08 AM
  5. Piss Poor MPG
    By Toofastgs in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-28-2008, 11:42 AM
