Thread: ABS,Traction Controll, and Speed Sensors issue.
Results 1 to 9 of 9
02Prix ABS,Traction Controll, and... 07-12-2010, 02:41 PM
Jakegday Re: ABS,Traction Controll,... 07-12-2010, 04:10 PM
Lawngoose Re: ABS,Traction Controll,... 07-12-2010, 04:12 PM
Jakegday Re: ABS,Traction Controll,... 07-12-2010, 04:54 PM
02Prix Re: ABS,Traction Controll,... 07-13-2010, 04:38 PM
AmericanRiceEater Re: ABS,Traction Controll,... 07-14-2010, 06:50 AM
twiggsta Re: ABS,Traction Controll,... 07-18-2010, 10:58 PM
NTrails Re: ABS,Traction Controll,... 07-23-2010, 01:58 PM
02Prix Re: ABS,Traction Controll,... 12-08-2010, 02:12 AM
  1. #1 Re: ABS,Traction Controll, and Speed Sensors issue.
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    one of your front abs sensor wires is deteriorating. as the wire gets worse, so will your problem.... its not necessarily the wire attatched to the hub/bearing itself, but more then likely the harness you plug them into
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  2. #2 Re: ABS,Traction Controll, and Speed Sensors issue.
    Outer Space
    Quote Originally Posted by Jakegday View Post
    Or you have bad wheel hub bearings. I do, and Trac Off and ABS Light up at the same time.
    02 GTP 13.6 @ 100mph - SOLD
  1. Replies: 25
    Last Post: 09-01-2010, 05:49 AM
  2. 98 GTP Traction control issue- Experienced help please!!
    By Liquifire in forum General Tech Discussion
    Last Post: 07-10-2009, 02:19 AM
  3. ignation controll modual priceing?
    By Rocket468 in forum General Tech Discussion
    Last Post: 05-27-2009, 09:36 PM
  4. Traction control issue?
    By NOVAZ27 in forum General Tech Discussion
    Last Post: 03-17-2009, 12:40 PM
  5. 2004 GTP traction control issue
    By bentendo92 in forum General Tech Discussion
    Last Post: 02-24-2009, 08:57 PM
