Thread: heater control swap
Results 1 to 4 of 4
  1. #1 heater control swap
    Donating Users nascartech's Avatar
    Abbotsford, British Columbia, Canada
    hi i was just wondering if it is possible to swap the heater switches from the slider type switch to the knob ones with the digital display and how to is it a staright swap thanks
    01 GTP is3 cam 130 springs double roller 60lb injectors lq4 maf headers 4000 stall lowered
    sold 97 GTP stock
    Sold 2001 gp gt ssm90 plog dp 3.8 208 whp 265 at the crank 14.8 1/4
  2. #2 Re: heater control swap
    Donating Users ninnyGTP's Avatar
    Nov 2008
    Moreno Valley, California
    No can do. The Digital is all electronic while the standard dual climate and standard controls are both vacuum controlled
    98 Grand Prix GTP L32, GenV, n*, 3.2", 1.9 rr's, 3.29 gears. All that jazz SOLD
    99 Mustang GT Steeda UDPs, 3.73s, Pypes O/R xpipe, Accufab plenum, Steeda CAI, B&M ripper, MHS s2 cams, 10.5:1 compression (290whp/310wtq) SOLD
    01 SVT Cobra #3654, B&M Ripper, K&N FIPK2, MAC O/R xpipe
  3. #3 Re: heater control swap
    Quote Originally Posted by ninnyGTP View Post
    well that sucks i found a set for 50 bucks they look nicer in my opinion what would i need to do just swap the wireing
    sold 97 GTP stock
  4. #4 Re: heater control swap
    Jan 2009
    MN
    I did this. You just need:
    Interior temp sensor (right of steering wheel, behind little grille)
    Exterior temp sensor (kind of by the radiator on the passenger side)
    Vacuum electric solenoid (little box w/ vacuum lines near the blower motor)
    Solar sensor (little dome on the dash)
    Both temp actuators (l and r sides of blower box)
    Blower motor control module (same place as blower motor resistor)
    Digital control unit (obv)
    You need a wiring diagram for both systems. It's all a wiring mess that you need to connect, salvage as much wiring as you can from a donor car. You can tap into the existing harness for power, ignition, ground, illumination, a/c request, rear defrost, that might be it.
    Unless you swap the entire huge blower box deal, you can only use one of the electric temp actuators (it is the same physical shape as the old one and just goes in the same place) thus you do not have the separate driver/passenger controls. Oh well. Be sure to wire up both anyway and leave the passenger one hanging somewhere so that the circuit isn't open. this will cause the little man icon to blink indicating an error code
  1. Need help with heater/ac control unit
    By Sameer in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-12-2009, 10:47 AM
  2. Need help with HEATER/AC CONTROL PLZZZ???
    Last Post: 10-28-2009, 09:50 AM
  3. Heater/ac control
    By Sameer in forum How To Write-Ups/Tech Tips
    Last Post: 10-25-2009, 08:08 PM
  4. Heater Control
    By TMC in forum General Tech Discussion
    Last Post: 11-27-2008, 07:42 PM
