Thread: at what pulley size do i need new injectors
Results 1 to 5 of 5
  1. #1 at what pulley size do i need new injectors
    SexyStudmuffin copperpacecar's Avatar
    Feb 2010
    somewhere cold
    as the title states im curious as to when i gotta switch out these stockers. i got a 3.1 pulley going on this week and it only just struck me that i may be getting close to my injectors limits with this pulley. if i am what injectors do u suggest i get
  2. #2 Re: at what pulley size do i need new injectors
    GTP Level Member
    Pittsburgh
    with a properly working fuel system, you typically run out with a 3.0 Pulley. That being said every car is different, and the only way to know for sure is to scan
    2003 SSEi,
  3. #3 Re: at what pulley size do i need new injectors
    Jersey
    Sorry to thread jack, but since we're on the topic...any idea at what pw the stock gtp injectors max out before going static?
    16' wrx sti- stock
  4. #4 Re: at what pulley size do i need new injectors
    once you start hitting 21.xx+ IPWs then youre close to maxing them or you already have. however, unless youre knocking then you should be okay.
  5. #5 Re: at what pulley size do i need new injectors
    I ran mine down to a 3.1"...and the injectors weren't running static but I had no IC OR Meth...I started to knock so it went bye bye and back up to the 3.25"
  1. pulley size?
    By bensett004 in forum General Tech Discussion
    Last Post: 05-13-2010, 01:43 PM
  2. Pulley size???
    By WHT98GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-10-2009, 02:01 PM
  3. To Pulley or not to Pulley is not the question.... SIZE IS
    By massivesystem in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-27-2009, 10:43 AM
  4. What size pulley and what size belt??
    By David99GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-15-2009, 08:55 AM
