Thread: Engine dies!?
Results 1 to 11 of 11
  1. #1 Engine dies!?
    Jun 2010
    Hampton, VA
    Hi all, Happy dad's day from the new guy.
    Yesterday the wife's '01 GT, N/A, 3.8 stopped running. In traffic, at a light. re-starting was effective if the gas pedal was held down "a little"
    My trouble shooting has been inconclusive. At first I had a P0327-Knock sensor 1 ckt low. checked, sensor generates signal Then a P1404- EGR circuit low. Next a P0131- O2 sensor 1 low volts. I cleaned the MAF sensor, the EGR valve, the IAT sensor. the only thing working is to hold the throttle. if I release it the rpm's drop to about 450 then stall.(in park)
    Any suggestions? Thanks in advance
  2. #2 Re: Engine dies!?
    Crank Shaft Sensor
  3. #3 Re: Engine dies!?
    Jun 2010
    Hampton, VA
    Thought of that. Engine runs fine if I hold the throttle. Also, when the crank sensor did go a couple of years ago, the traction control shuts off and the tach dies. Currently have no codes.
  4. #4 Re: Engine dies!?
    Willoughby, Ohio
    dirty throttle body? did you try unpluggin the MAF to see if that helped? maybe its just bad
  5. #5 Re: Engine dies!?
    Jun 2010
    Hampton, VA
    Suspecting bad MAF or possibly the TPS. Unplugging the MAF had no effect. Ran the same, stumbling at about 450 then dies. Any other suggestions are welcome. I hate to "easter-egg" with those sensors, They tend to be pricey.
  6. #6 Re: Engine dies!?
    New Jersey
    Mine was doing the same thing and it ended up being the MAF sensor. Stalling at street lights or when decelerating quickly.
  7. #7 Re: Engine dies!?
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Need to scan and see whats going on, Otherwise its a shot in the dark. Could be MAF.TPS.MAP. Vac leak. ect
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  8. #8 Re: Engine dies!?
    if you unplugged the MAF and nothing changed then its not the MAF.
  9. #9 Re: Engine dies!?
    Jun 2010
    Hampton, VA
    It's fixed. It would seem, if I understand correctly,the MAP sensor takes over air mass monitoring at volumes below the MAF sensing threshhold. If the MAP sensor becomes temperature sensitive, it cuts out at normal operating temps. When the engine goes into a high vacuum condition, idling or deceleration, and the MAP is not sending a good signal, the engine dies due to fuel starvation. never did get a code though...
  10. #10 Re: Engine dies!?
    Jun 2010
    Hampton, VA
    I guess I spoke too soon. wife took it to the c-store yesterday. Started and ran fine. Leaving the store, same thing. Had to two-foot it to get it home. I've changed MAF, MAP, TPS, Cleaned IAT, EGR and IAC. Checked for vacuum leaks. I got a code for the #1 knock sensor "signal low" (P0327) Can anyone help?
  11. #11 Re: Engine dies!?
    Jun 2010
    Hampton, VA
    Now for the real fix. In re-checking EVERYTHING, I pulled the IAC and turned on the key. I then turned off the key and retrieved the IAC plunger from the exhaust manifold. Since it directly regulates the idle speed and had mechanically failed, no codes related to it. basically a massive vacuum leak inside the throttle body. Tends to cause poor performance, especially at idle.
  1. Car starts then dies
    By silver2000se in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-18-2010, 06:33 PM
  2. 98 gtp engine stall restart dies
    By troubled in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-07-2009, 05:57 PM
  3. Car Dies
    By kfish in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-28-2009, 04:14 PM
  4. Driving on express way at 65 mph, engine dies! What the???
    By 03GPScottyd in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-07-2009, 03:10 PM
  5. Car Dies out!???
    By letsndy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-21-2008, 03:47 PM
